Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 03-09-2017, 08:41 PM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default '96 Indy Lite Ignition Timing
Hello,
Looking through the service manual I have, it does not list the timing curve for the 340 engine.
Found specs. for a '99 Indy 340 on the 'net:
- 26.5 deg. @ 3000 RPM
- 15.5 deg. @ 7000 RPM
Anyone know if these specs. would work for the older engines?
Also, has anyone tried advancing the timing past stock specs. on these machines with any success?
CDI remapping?
Would like to improve throttle response if possible.
TIA,
Glen
Rate this post: Yes | No
  #2
Old 03-09-2017, 10:06 PM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
My book only goes to the 1993 model.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to volcano buster For This Useful Post:
Merlin (03-09-2017)
  #3
Old 03-09-2017, 11:01 PM
Merlin's Avatar
Default
Thanks VB!
Looks like the later 340s are more advanced at lower speed but slightly retarded at the top end.
I'll just have to check mine to see where it's at & go from there.
  #4
Old 03-21-2017, 11:36 AM
olymon's Avatar
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
Maybe adapt a flat slide or install UFO inserts into the carb if you are just looking for throttle response.
The Following User Says Thank You to olymon For This Useful Post:
Merlin (03-21-2017)
  #5
Old 03-21-2017, 12:45 PM
Merlin's Avatar
Default
Thanks for the info.
The flat slides would be ideal like TRS did with his 550s but I'll have to put a cap on the engine budget for now to make sure there are funds for the chassis / suspension / steering upgrades next year.
Have you used the UFOs in the 340 fan application before? The benefits sound fine on paper but like many of the mods. out there, are they actually worth it?
  #6
Old 03-21-2017, 01:01 PM
Merlin's Avatar
Default
Well, it always helps if you read the manual..........in it's entirety. The timing specs. were there all along. In the battery section & not where I was expecting to find them but were there nonetheless. LOL
Anyway, the specs. for the '96 were the same as the '99.
Upon checking, the 340 was running 24.5 deg. BTDC @ 3000 RPM. So, I tweaked the stator plate a bit but not quite enough & only increased it to 25.5 BTDC.
I ended up dropping the pilots from 35 to 30 as well so I wanted to try that along with the increase in timing to see the effect on bottom end. Will likely bump it up a few more degrees next season pending satisfactory plug checks......
Ended up having "issues" with my sled the day we went to ride so we only got a small chance to test the Indy Lite but from what we could tell, the improvement was significant / noticeable. It was good thing the Indy was running better cause it had to pull my Pro back to the truck. LOL!
The Following User Says Thank You to Merlin For This Useful Post:
volcano buster (03-23-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — ignition timing Thread Starter — ullose272 Forum — Polaris: EDGE Replies — 0 Last Post — 01-24-2010 07:18 PM
Thread — ignition timing sensor Thread Starter — Goin For Snow Forum — Arctic Cat: 1M Replies — 2 Last Post — 01-19-2010 12:40 PM
Thread — ignition timing? Thread Starter — ullose272 Forum — Polaris: EDGE Replies — 10 Last Post — 09-26-2009 09:41 PM
Thread — ignition timing Thread Starter — 98 xcr 440 Forum — Polaris Replies — 1 Last Post — 12-12-2008 11:22 PM
Thread — ignition timing Thread Starter — 98 xcr 440 Forum — Performance/Modified Replies — 0 Last Post — 12-12-2008 09:10 PM
no new posts
