Upgrade to Premium
Member Sled Builds A forum for building a project or mod sled.... Not just your common "Mods", but full on sled build projects.
Reply
  #1
Old 03-07-2017, 07:19 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default Turbotater's Porting and Performance Pro RMK 910 big bore install with photos
Wayde Turbotater Johnson has always been known as a GREAT engine guy. He has been porting and tuning two-strokes since the 1970s.
He KNOWS pipe mods and clutching.
He is the innovator of the reed valve system in the airbox of carbed two-stroke turbo sleds.
Over a decade ago, I posted on here about where to take my sled for some work on my PSI motor. I asked about PSI, SLP, Doug Ruth...etc etc. Many people suggested those...but the overwhelming majority said to take it to Wayde Johnson in Hazelton, ID. So I did. SMART MOVE.
He took the engine that Bruce Kalhammer (from PSI Performance) called a "full race ported" 1155cc twin that was supposed to run on 50% race gas engine and massaged it over. He reshaped the ports and cleaned it up a bunch so the fuel mixture went to the center of the piston instead of elsewhere.
Wayde said to dump the PSI pipes (which is where Bruce got his start in the 1970s and did quite well with them). Wayde made a pipe suggestion and helped find a set. Did a little clutch work and away we went. That engine came alive and ran like a scalded dog...NOT ON 50/50 RACE GAS, but with just ONE gallon of race gas to take the edge off.
Wayde did a fantastic job for me. I quickly learned to trust that other people's recommendations were RIGHT about him.
In 2009, I had Wayde build the clunker 2003 800 ves engine than I bought on the internet. He turned that think into a monster and it ran VERY well for 4 seasons for me until I sold it. And it's still running today as if it were brand new.
SO, Wayde is more honest than the day is long. He is a straight shooter and doesn't buy into hysteria or hype. He does what works and he does it because he's working from hands-on experience. He doesn't push things out to the limit, but makes them run REALLY well in spite of that.
Wayde has done porting and engine work for a lot of other bigger named companies. They sent their stuff to him and had him do it to their specs. He learned a lot about how he would do it different and built a library of his own specs. He did a lot of King Cat and M1000 port jobs that jpeople would swear there was more two it.
He'd gotten into partnering the 850/858 big bores from M2W a couple years ago, but now he's partnered with Stroker Customs in Colorado to make a 962 stroker big bore. Wayde is also making his own 910 big bore for the Pro and Axys engines.
Given Wayde's fantastic reputation and my own personal experience with him, I felt like I could go with his 910 big bore. I was one of his first 910 builds.
Back in December, I loaded up the sled and my son on a Friday night and headed for southern Idaho for "a fresh top-end" .
I had the upper case half ported a couple weeks before that, so it was ready to "bolt on" when we got there.
Here is the build and ride report.....
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to Scott For This Useful Post:
4GR8X (03-09-2017), mountainhorse (03-08-2017), richracer1 (03-08-2017), Turbotater (03-08-2017)
  #2
Old 03-07-2017, 07:24 PM
Scott's Avatar
Garage
Default
T8rz Porting and Performance is not some big shop. It's a very small one-man outfit that pays CLOSE attention to detail.
Wayde builds these out of his own garage in Hazelton Idaho.
He doesn't do this work for a business because he has to, he does this for fun because he WANTS to. That's why he's GREAT at it.
This is his porting bench in the garage. He backs the wife's car out so he can work.
The porting bench.
A completed 962 stroker ready to ship.
My box of parts ready to go.
The chassis. 2013 Pro RMK.
Click image for larger version
ID:	282278   Click image for larger version
ID:	282279   Click image for larger version
__________________
Ambassador for:
The Following 3 Users Say Thank You to Scott For This Useful Post:
4GR8X (03-09-2017), jthussey (03-16-2017), mountainhorse (03-08-2017)
  #3
Old 03-07-2017, 07:29 PM
Scott's Avatar
Garage
Default
I wasn't going to take any chances, so the first thing I did was take pictures off all the wire harness plug-ins before we pulled everything apart for the assembly of the top-end kit.
ID:	282282   Click image for larger version
ID:	282283   Click image for larger version
ID:	282285   Click image for larger version
__________________
Ambassador for:
The Following 2 Users Say Thank You to Scott For This Useful Post:
  #4
Old 03-07-2017, 07:35 PM
Scott's Avatar
Garage
Default
We left the engine in the chassis and left the carbon fiber over-structure in place.
It's a gamble, but it wasn't too bad until the end when we were putting the exhaust springs on. THAT story will come later. LOL
As I said in the first post, the upper case half was already ported ahead of time. You gotta make room for the piston skirts..
ID:	282287   Click image for larger version
ID:	282288   Click image for larger version
__________________
Ambassador for:
  #5
Old 03-07-2017, 07:39 PM
Scott's Avatar
Garage
Default
Studded cylinders and heads are the ONLY way to go.
Used two nuts and driver to turn them into the cylinders.
ID:	282292   Click image for larger version
ID:	282293   Click image for larger version
ID:	282295   Click image for larger version
__________________
Ambassador for:
  #6
Old 03-07-2017, 07:44 PM
Scott's Avatar
Garage
Default
Yes, we used plenty of assembly lube.
Sleeved and ported cylinders
Some welding put in here to reinforce the cylinders. This helps to make room for wider boost ports.
Prepping the wrist pin
ID:	282297   Click image for larger version
ID:	282298   Click image for larger version
__________________
Ambassador for:
  #7
Old 03-07-2017, 07:51 PM
Scott's Avatar
Garage
Default
Getting closer.
A little heat to properly seat the domes.
ID:	282301   Click image for larger version
ID:	282302   Click image for larger version
ID:	282304   Click image for larger version
ID:	282305   Click image for larger version
__________________
Ambassador for:
  #8
Old 03-07-2017, 11:06 PM
slash's Avatar
slash slash is offline
Currently: ahhh back to work
Parts Moderator & Chat Box Cop
slash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond repute
Garage
Default
aww Scott you should have done the 962 it flat rips , If you would have made the Tog ride you could have .....
__________________
09 IQ
KMOD
RAPTORS
2.5 CE
MOHAWKS
SLP PIPE
KOOLME KUSTOMS 660 KIT
TATERSPORTING PORTWORK
[IMG]//www.snowest.com//www.snowest.com/i/snowest-forum-logo.jpg[/IMG]
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to slash For This Useful Post:
4GR8X (03-09-2017), Scott (03-08-2017)
  #9
Old 03-08-2017, 12:40 AM
Scott's Avatar
Garage
Default
Installing the Wisecos.
Assembly lube required.
ID:	282322   Click image for larger version
ID:	282323   Click image for larger version
ID:	282325   Click image for larger version
__________________
Ambassador for:
  #10
Old 03-08-2017, 01:25 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
The Following 2 Users Say Thank You to mountainhorse For This Useful Post:
  #11
Old 03-08-2017, 09:58 AM
Scott's Avatar
Garage
Click Here to Register
  #12
Old 03-08-2017, 12:34 PM
Scott's Avatar
Garage
The Following User Says Thank You to Scott For This Useful Post:
4GR8X (03-09-2017)
  #13
Old 03-08-2017, 06:41 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #14
Old 03-08-2017, 06:49 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #15
Old 03-08-2017, 06:53 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #16
Old 03-08-2017, 06:57 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #17
Old 03-08-2017, 06:59 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #18
Old 03-08-2017, 07:03 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #19
Old 03-08-2017, 07:07 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #20
Old 03-08-2017, 07:11 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #21
Old 03-08-2017, 07:17 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #22
Old 03-08-2017, 07:23 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #23
Old 03-08-2017, 07:36 PM
Scott's Avatar
Garage
  #24
Old 03-08-2017, 07:48 PM
Scott's Avatar
Garage
4GR8X (03-09-2017)
  #25
Old 03-08-2017, 07:56 PM
Scott's Avatar
Garage
4GR8X (03-09-2017), mountainhorse (03-11-2017), sledhead9825 (03-09-2017), wellfed777 (03-14-2017)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 910 big bore Thread Starter — D McGregor Forum — Engine/Engine Parts (Swapmeet) Replies — 3 Last Post — 06-15-2013 11:36 PM
Thread — Turbo porting vs big bore porting?????????? Thread Starter — HardKor Forum — Arctic Cat: TURBO Replies — 3 Last Post — 02-05-2011 08:23 PM
Thread — 02 edge 910 big bore Thread Starter — cs27 Forum — Polaris (Swapmeet) Replies — 20 Last Post — 06-26-2010 11:03 AM
Thread — F/S 05 RMK w/ 910 big bore Thread Starter — tgremaux Forum — Polaris (Swapmeet) Replies — 3 Last Post — 02-06-2008 03:19 PM
Thread — F/S 05 RMK w/ 910 big bore Thread Starter — tgremaux Forum — Polaris (Swapmeet) Replies — 0 Last Post — 01-30-2008 09:12 AM
no new posts
