Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 03-06-2017, 07:29 PM
Novanut18 Novanut18 is offline
Currently: Not set.
Basic Member
Novanut18 is an unknown quantity at this point
Default dies after riding about 3-4 miles
so I first want to say hi and thank you to every one who responds second I would like to say I have done a lot of searching about my problem but it seams there isn't one like this one so like the title says it dies after 3-4 miles running It loses spark and it need to cool down before re starting and then it only runs for a little bit and then dies again I mean loses spark so I tried unplugging kill switch and ignition switch still no difference I also want to say this has been a problem for a while there was two stators put in a voltage regulator and a ecu put in I have tried backing pins out of the conector next to the ecu and trying to single out a problem but seam to have created another one or made it worse I put it all back to geather like factory and now wont start I get a initial spark and then no bang or another spark only sparks one time when I pull and sometimes its two pulls and I get a spark I have great fuel pressure and I don't know what to do seams like no one wants to work on them I would love the input thank you guys
Rate this post: Yes | No
  #2
Old 03-06-2017, 09:40 PM
Cerialsledder's Avatar
Cerialsledder Cerialsledder is offline
Currently: Flatlanderextraordinaire
SnoWest Badge Maker
Cerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond repute
Garage
Default
You put in everything else but the coils. Have you tried a different coil?
__________________
  #3
Old 03-07-2017, 09:32 AM
SixtySevenGT's Avatar
SixtySevenGT SixtySevenGT is offline
Currently: Building Sleds
SixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond repute
Default Fix the last thing you messed with -- Then
So right now it won't run at ALL ?
Seems like you messing with the connector caused this problem. Fix the connector then get it to run cold again.
Plug wires / Plug Boots / Coil ?
Wires and boots are cheap and easy to get to.
Are your plug wires touching anything ?
When it warm ups they could be shoritng out.
When it dies does it shut down hard or start missing first ?
__________________
"Always Drink Upstream from the Herd"
  #4
Old 11-29-2017, 09:11 AM
memyself2 memyself2 is offline
Currently: Not set.
memyself2 is an unknown quantity at this point
Garage
Default No spark
Did you get it sorted out?
My 05 Fusion 900 was doing the same thing.
Did you put in a new stator or a used one?
I found that my original stator wires had rubbed through the insolation and would all of a sudden die. A short while later it would restart.
I patched up the wires and was good for 1000 miles or so, till the problem returned.
By this time I had purchased a used parts engine at a good price, just in case. I removed the stator from the parts motor as it looked to have been newly replaced. After inspecting it, approximately 30% of the wires in it's harness were broken.
I think it was an aftermarket stator and the wire used in it's construction was not flexible enough.
I then replaced all the wires in it's harness with better quality wire, and knock on wood it has been perfect for the past 2000 or so miles.
  #5
Old 11-29-2017, 12:40 PM
live2beel live2beel is online now
Currently: Not set.
live2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond repute
Default
My pro was doing the same thing. It ended being all the ground wires on the shock tower.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Dragon dies while riding, then runs on 1 cylinder Thread Starter — Twisted Tunnel Forum — Polaris: IQ Replies — 7 Last Post — 12-25-2013 11:35 AM
Thread — sled bogs and then dies after a couple of miles Thread Starter — happyfast79 Forum — Polaris Replies — 2 Last Post — 04-08-2009 09:38 PM
Thread — 08 M8 Dies Thread Starter — philsummers21 Forum — Arctic Cat Replies — 11 Last Post — 04-07-2009 02:55 PM
Thread — 98 RMK 700 Dies after running for few minutes of riding. Thread Starter — BurkeMtn Forum — General Snowmobiling Replies — 6 Last Post — 12-29-2008 02:35 PM
Thread — Evil dies and Jimmy blaze almost dies with link Thread Starter — Trees4Traction Forum — General Snowmobiling Replies — 16 Last Post — 12-02-2007 11:00 AM
no new posts
