Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 03-03-2017, 02:39 PM
87gtNOS 87gtNOS is offline
Currently: Not set.
Basic Member
87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute
Default Low comp. pistons vs. head shim APEX
which would be better when doing rods and pistons....head shim or low compression pistons?
I'm doing rods and pistons this summer in my 2012 Apex....
Thanks
Rate this post: Yes | No
  #2
Old 03-04-2017, 05:12 PM
up-high's Avatar
up-high up-high is online now
Currently: New femur and a new knee and more metal in hip!!
up-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond repute
Default
If you are doing pistons anyway, do low comp. Going to run big boost? Do upgraded rods as well. Had Apex with both and think throttle response was better with pistons. Could have been trying to justify the purchase.
__________________
65/121 It don't get any lighter!
BERRGG
It's Mountainhorse time now!!!
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to up-high For This Useful Post:
Snowmixer (03-06-2017)
  #3
Old 03-06-2017, 09:09 AM
roughrider99's Avatar
roughrider99 roughrider99 is offline
Currently: the stutter button on the tnytro is too much fun!
roughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond reputeroughrider99 has a reputation beyond repute
Garage
Default
Also headshim is less reliable compared to low comp pistons in terms of the head gasket, headshim has potential for 2 sealing surfaces for sale while low comp pistons leaves the original sealing surface and single head gasket.
__________________
I ride where its steep n' deep
17' 800 T-axys LE
16' 600 axys pink ribbon (hers)
15' viper mtx 162 PC3
12' pro rmk (for sale)
97 wrx sti type r summer boosted toy!
  #4
Old 03-06-2017, 03:10 PM
kinger9 kinger9 is offline
Currently: Waiting for SNOW!
kinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond reputekinger9 has a reputation beyond repute
Default
Headshim is just fine for reliability. I was more scared to do low CR pistons and re-nikasil the cylinders to do it 'right'. Also pick your pistons carefully and rings so they don't knock or burn oil. Stock with headshim is hard to beat up to about 15 psi. Over 15 psi you need rods and pistons and take the trade off of some possible slapping and oil consumption.
__________________
2017 Yamaha Sidewinder B-TX SE...mods coming soon
The Following 2 Users Say Thank You to kinger9 For This Useful Post:
HANDSOME (09-14-2017), zx4ever (03-07-2017)
  #5
Old 03-06-2017, 11:25 PM
Octanee Octanee is online now
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
Quote:
I ran 17-18 psi on my apex regularly, odd spike to 20#, elevation ~5500feet all she had was a head shim, absolutely no issues
  #6
Old 03-07-2017, 08:34 AM
M5- M5- is online now
Currently: Planning a build
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
Default
If you use a head shim which IMO is fine up to 17 lbs on an Apex, use a stainless steel one, I've blown out an aluminum one before.
M5
  #7
Old 03-07-2017, 09:19 AM
Currently: Not set.
Basic Member
Default
Thanks guys for the input.
I was thinking CR pistons from Hurricane which use the stock Yamaha rings.
Along with Carillo Rods...
I assume the pistons he sells for this (10 to 1, I think) are suitable for NO headshim and a 290 kit? I know he can answer that when the time comes I guess....
  #8
Old 03-07-2017, 09:21 AM
Currently: Not set.
Basic Member
Default
Quote:
M5
I have whatever headshim it is that comes with the MCX 290 kit in it right now....I didn't install it, so I'm unsure the material.
  #9
Old 03-07-2017, 09:24 AM
Currently: Not set.
Basic Member
Default
I have run about 13.6 psi....on 91 octane (with maybe some Shelbourne fuel additive, not sure if it works!) and that 13.6 could also be a spike from letting off the gas....but anyways, I just want to build this motor with rods and pistons ready for C12 and about 16 psi boost for grudge racing!
The Following User Says Thank You to 87gtNOS For This Useful Post:
n1lzen (03-17-2017)
  #10
Old 03-07-2017, 07:44 PM
sledfvr's Avatar
sledfvr sledfvr is offline
Currently: It's 13 years old,13'long,700lbs,350hp
sledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond reputesledfvr has a reputation beyond repute
The Following User Says Thank You to sledfvr For This Useful Post:
87gtNOS (03-07-2017)
  #11
Old 09-14-2017, 11:06 PM
HANDSOME HANDSOME is offline
Currently: Not set.
HANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond repute
Click Here to Register
  #12
Old 11-19-2017, 04:31 PM
gunnerthesnowman's Avatar
gunnerthesnowman gunnerthesnowman is offline
Currently: Got to love boost and love the new pro
gunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond reputegunnerthesnowman has a reputation beyond repute
  #13
Old 11-20-2017, 06:42 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Low comp head and e key together Thread Starter — Duraslut Forum — Arctic Cat: TURBO Replies — 9 Last Post — 11-26-2012 10:31 PM
Thread — F/S 09 Apex motor with low miles & head shim.. Thread Starter — Polarisrocks Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 04-03-2012 04:35 PM
Thread — je pistons vs head shim Thread Starter — boost4life Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 26 Last Post — 10-11-2010 12:26 PM
Thread — wtb low comp head for 800 non ves Thread Starter — Prox700Man Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 08-19-2009 02:57 PM
Thread — Wtb: Low comp head for 04 proxr 440 Thread Starter — snirtrider Forum — Racing Replies — 1 Last Post — 10-17-2008 10:49 AM
no new posts
