Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 03-01-2017, 09:04 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default Nytro/Phazer Premium ROV kit now with Quick Prime!
Guys,
I have expanded the oil pump re-prime feature used in our Viper Roll Over Valve kits to the Nytro/Phazer premium ROV kits!
Sometimes if the oil pump is allowed to suck in air during a roll over event it may loose prime. When this happens the sled may start and run for a few seconds, then shut down due to no oil pressure. In the past to re-prime the oil pump, the options were to tip the sled and let it sit for a extended period of time. Or pull the right hand side cover and block/restrict the breather line to allow pressure to build in the oil tank.
With the Quick Prime system, you simply push and hold the Quick Prime switch down while starting the sled. The ROVCM commands the ROV shut off valve to close which allows the oil tank to build pressure. The air pressure then forces oil to the oil pump for re-priming.
The re-priming process usually only takes a couple of seconds and literally is as easy as pushing/holding a button!
I have more info/pics at http://fourstrokesolutionsllc.webs.c...e-kit-features
Bill
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New Roko Quick Strap Kit and New Scott Quick Strap Kit Thread Starter — Seeker Forum — Goggles (Swapmeet) Replies — 2 Last Post — 03-06-2017 05:35 AM
Thread — fx nytro / phazer 2010-2013 handwarmer kit Thread Starter — motorex Forum — Yamaha (Swapmeet) Replies — 0 Last Post — 01-07-2015 07:35 PM
Thread — YAMAHA PHAZER - Premium Cover - NIB Thread Starter — Firetrail Forum — Misc. Sled Parts Replies — 1 Last Post — 12-26-2014 05:45 PM
Thread — nytro crank chase oil prime Thread Starter — rymo84 Forum — Nytros! Replies — 3 Last Post — 12-09-2010 10:14 AM
Thread — Premium Gas for Stage II MPI SC Nytro? Thread Starter — yzf400r Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 3 Last Post — 01-29-2010 12:04 PM
no new posts
