Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 03-01-2017, 04:24 PM
87gtNOS 87gtNOS is offline
Currently: Not set.
Basic Member
87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute87gtNOS has a reputation beyond repute
Default LAG. 290mcx at 12 psi 2012 Apex XTX
Alright, here's an issue I've come to live with when riding normally....but, out on the lake (btw, I'm a flatlander) when I pin on it (out of the hole or when moving) the lag is bad enough that the Sidewinder I'm with will pull away right away.
I contribute this to maybe clutching.
Set up as follows.
GForce weights loaded to 92 grams...fairly flat profile.
WGW 40 2.25 111
52-46 helix
white secondary at 3-3
25-37 gears, 1" track (144")
Pulls hard, works good on the trail. Clutches stay cool.
Ideas? Trying to stay away from the EPI Purple sec spring!
Thanks
Rate this post: Yes | No
  #2
Old 03-01-2017, 04:31 PM
Currently: Not set.
Basic Member
Default
more info...
Have Innovate SCG1 controller....set at 32% waste gate and spring pressure at 7.5 and played with GAIN....what I think is when it is at 18% it might spool (correct word?) quicker and at 20% I think it would hit rev limiter....
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 03-01-2017, 09:47 PM
Octanee Octanee is offline
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
Is your apex a mid mount or rear mount kit? My rear mount already being bad for lag, had even worse lag, the first test is plug your exhaust with your hand, Ideally the sled should stall out, Means your exhaust is sealing well, if it idles down and sputters, well you have a leak somewhere but maybe It wont be the end of the world, if it idles just fine with exhaust plugged then you have a leak you really need to fix, Of course any leak is not a good leak, in my case my muffler is rusty and I know its leaking a bit from that.
Second thing if the exhaust passes the test, is a boost leak, I was surprised at how that really caused extreme lag, but go figures right?
I went to a hardware store and got a PVC pipe cap that would fit into my intake for where the turbo sucks air, I then drilled a hole and threaded in my air fitting, its a pipe thread and plastics somewhat soft it made a good seal. I turned down my compressed air to about 20 PSI and could hear it hissing all over. you may need to rotate your crank by your clutch by hand to get it it to where it wont leak through a cylinder due to valve over lap. My throttle bodies leak, which you can't really fix, a small leak but what can you do lol,
  #4
Old 03-02-2017, 07:22 AM
Currently: Not set.
Basic Member
Default
Mine's a 2012...so I believe they call them mid mount.
I understand what you're saying about leaks...I'd test that this summer, but I'm going to tear it all apart and install rods and pistons.
I'll pay close attention to detail when I put it together to make sure there are no leaks.
Thanks for your input.
  #5
Old 03-04-2017, 08:52 PM
HANDSOME HANDSOME is offline
Currently: Not set.
HANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond repute
Default
Sorry to hijack this but how long did it take to catch the Winder ? I want a 11 or newer apex for the power steering....and boost lol
  #6
Old 03-04-2017, 10:40 PM
stingray719 stingray719 is offline
Currently: 2014 Viper MTX conversion
stingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond repute
Default
Try a GWG spring, flat profile weights get lazy if they don't have a stiff spring. The other thing that helps is a reverse helix. Let the boost build before you shift up. Took my 43 out of my boosted Viper and put a 40/46 in, do the math to guess on one for yours. Dalton sells them
  #7
Old 03-05-2017, 06:56 AM
Currently: Not set.
Basic Member
Default
Quote:
at 100mph I would be slingshotting past, but they let off! LOL
  #8
Old 03-05-2017, 07:27 AM
Currently: Not set.
Basic Member
Default
GWG has a 136 finish....how do I overcome the added rpm up top?
  #9
Old 07-31-2017, 04:32 PM
Currently: Not set.
Default
Sorry I'm not much help but is it clutched for 290hp ?
  #10
Old 10-10-2018, 07:38 PM
Currently: Not set.
Basic Member
  #11
Old 10-16-2018, 04:52 PM
Currently: Not set.
Click Here to Register
  #12
Old 10-18-2018, 03:35 AM
Climbmax's Avatar
Climbmax Climbmax is offline
Currently: Hello Drama and Karma...you related?
Climbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond reputeClimbmax has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Altitude Clutching Apex XTX Thread Starter — Mark's RMK Forum — Yamaha: 4-Stroke Replies — 3 Last Post — 01-20-2014 12:26 PM
Thread — 2012 M8 Anti-lag button Thread Starter — BarkBustnOutlaw Forum — Arctic Cat: TURBO Replies — 6 Last Post — 11-10-2013 07:22 AM
Thread — WTB Apex XTX Thread Starter — royalblue Forum — Yamaha (Swapmeet) Replies — 2 Last Post — 11-22-2012 11:55 PM
Thread — Handguards for an Apex XTX Thread Starter — Mark's RMK Forum — Yamaha: 4-Stroke Replies — 1 Last Post — 04-12-2012 09:15 PM
Thread — apex xtx?? Thread Starter — twincam88 Forum — Yamaha Replies — 1 Last Post — 12-04-2009 12:11 AM
no new posts
