Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-28-2017, 10:12 PM
kgra kgra is offline
Currently: Not set.
kgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond repute
Talking Mtntk mapping on Silber pro is an improvement
Ive been battling the bog and stutters associated with my 2014 pro rmk since the Silber Turbo ecu reflash kit first came out. After the first year silber came out with an update which is decent. Works great on the trail but to often stutters and cuts out in the steep and deep or heavy snow of the BC mountains when in and out of the throttle. I finally decided to try mtntk tune on it and had my first day ever with no bogs or stutters. It was the best day ever!! I haven't done any long pulls yet. But also had no more lean popping on the trail on the way down the mountain when in and out of the throttle.
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 6 Users Say Thank You to kgra For This Useful Post:
Ckale (09-13-2017), grahamindus (02-15-2018), kcpete (03-02-2017), roni87 (03-01-2017), Sunvang (03-01-2017), wellfed777 (02-28-2017)
  #2
Old 02-28-2017, 10:23 PM
wellfed777 wellfed777 is online now
Currently: Not set.
wellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond repute
Default
good info keep us posted as you get more time on it
  #3
Old 03-06-2017, 02:30 AM
Currently: Not set.
Default
Rode in some deep and steep snow today 4000-5500ft. The tune worked awesome upto 8 psi. As I turned boost up to 10psi then 12 I lost rpm progressively and it sounded rich. Maybe I didn't have enough octane. No lights come on. I'll try more octane next week. I was 40% 94 and 60%c111. C111 is the same barrel as c110 which is sold in the US. just a different sticker according not to VP.
The Following User Says Thank You to kgra For This Useful Post:
THRILL_SEEKER (03-28-2017)
  #4
Old 03-06-2017, 09:22 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Quote:
Don't forget, as you go up in boost, you create more heat. At a point, you start chasing your tail as the charge air is so hot its actually a lot less dense to the point that you are losing power at higher boost.
Without an intercooler, there is a happy balance somewhere - part of it will depend on outside conditions, part of it will depend on your elevation. Fuel even can change things (depending on how "hot" or "cold" the fuel burns).
Hope that helps.
The Following 2 Users Say Thank You to JJ_0909 For This Useful Post:
grahamindus (02-15-2018), sledhead9825 (03-06-2017)
  #5
Old 03-06-2017, 10:26 AM
sledhead9825 sledhead9825 is offline
Currently: Not set.
sledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond repute
Default
[QUOTE=kgra;4060055]Rode in some deep and steep snow today 4000-5500ft. The tune worked awesome upto 8 psi. As I turned boost up to 10psi then 12 I lost rpm progressively and it sounded rich. Maybe I didn't have enough octane. No lights come on. I'll try more octane next week. I was 40% 94 and 60%c111. C111 is the same barrel as c110 which is sold in the US. just a different sticker according not to VP.[/QUOTE
I agree with JJ, at 10 PSI plus and no intercooler your intake temps would be very high. You have more than enough octane with your current mix. I run my MTNTK at 9ish lbs with 25% C12 and Shell 91. Are you riding the Coast?
  #6
Old 03-06-2017, 10:46 AM
B&M Fabrications's Avatar
B&M Fabrications B&M Fabrications is offline
Currently: Working
SnoWest Sponsor
B&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond reputeB&M Fabrications has a reputation beyond repute
Default
Do you run an AFR guage on it? You can piggy back the ECU with a PCFC power commander and do your own tuning to get it dialed in. Without a guage though you are playing with fire.
Sent from my SM-G928V using Tapatalk
__________________
Visit us online at www.Bmfabrications.com!
Shop: 612-202-9245
E-Mail: Info@bmfabrications.com
Social Media Accounts
facebook.com/burlybmfab
Instagram: @burlybmfab
Twitter: @burlybmfab
  #7
Old 03-06-2017, 11:26 AM
Currently: Not set.
Default
I ride Merritt to Hope mountains.
With silbers tune I can pull hills upto 14psi boost but the problem with there tuning is at any boost level when on hard pull soon as you let off the throttle and get back in to it it dies. It's very unsafe. Silbers bogs when tree riding aswell. Shawn said he'd make some adjustment if something wasn't right so we will see how it ends up. For now atleast I can ride 8psi and get back to pushing myself without the worry of the sled falling in its face.
  #8
Old 03-07-2017, 01:08 PM
Currently: Not set.
Default
so all you did was send mtntk your ecu ?
nothing else ?
  #9
Old 03-07-2017, 11:53 PM
Currently: Not set.
Default
Quote:
nothing else ?
I have a Bullydog. They sent me a file via email, I load it to SD card, insert SD card in Bullydog and reflash the ecu myself.
wellfed777 (03-08-2017)
  #10
Old 03-08-2017, 01:27 AM
Currently: Not set.
  #11
Old 03-09-2017, 12:13 AM
Currently: Not set.
Click Here to Register
wellfed777 (03-09-2017)
  #12
Old 03-09-2017, 07:46 PM
Currently: Not set.
  #13
Old 03-09-2017, 10:25 PM
Currently: Not set.
wellfed777 (03-10-2017)
  #14
Old 03-09-2017, 10:46 PM
revrider07 revrider07 is offline
Currently: 850 modder
revrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond reputerevrider07 has a reputation beyond repute
The Following 2 Users Say Thank You to revrider07 For This Useful Post:
grahamindus (02-15-2018), THRILL_SEEKER (03-28-2017)
  #15
Old 03-09-2017, 11:15 PM
Currently: Not set.
  #16
Old 03-10-2017, 07:16 PM
Ski-Dont89 Ski-Dont89 is offline
Currently: Parting out a 2009 RMK 700 155" PM ME
Ski-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond reputeSki-Dont89 has a reputation beyond repute
Garage
  #17
Old 03-10-2017, 07:19 PM
NWaxys NWaxys is offline
Currently: ridecascade.com
NWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond reputeNWaxys has a reputation beyond repute
  #18
Old 03-10-2017, 07:30 PM
Currently: Not set.
  #19
Old 03-10-2017, 10:27 PM
roni87 roni87 is offline
Currently: Not set.
roni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond repute
  #20
Old 03-10-2017, 11:21 PM
  #21
Old 03-27-2017, 09:04 PM
Currently: Not set.
  #22
Old 09-13-2017, 10:19 AM
Ckale Ckale is offline
Currently: Not set.
Ckale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond reputeCkale has a reputation beyond repute
  #23
Old 11-30-2017, 09:47 PM
yukonrider yukonrider is offline
Currently: Not set.
Basic Member
yukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond reputeyukonrider has a reputation beyond repute
  #24
Old 12-01-2017, 03:42 PM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
  #25
Old 01-20-2018, 09:45 AM
Currently: Not set.
The Following User Says Thank You to Ckale For This Useful Post:
roni87 (01-22-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Does anyone run MTNK's mapping on a silber Pro Thread Starter — tratch2 Forum — Polaris: TURBO Replies — 16 Last Post — 01-02-2017 11:02 AM
Thread — MTNTK or Silber kit for the axys? Thread Starter — Sunvang Forum — Polaris: TURBO Replies — 26 Last Post — 09-09-2016 10:21 PM
Thread — bmp or mtntk 800 pro durability kit Thread Starter — hontri Forum — Polaris: Pro-Ride Replies — 1 Last Post — 03-04-2015 05:15 PM
Thread — 13' PRO & MTNTK Full Mod?? Thread Starter — Hopfarmer Forum — Polaris: Pro-Ride Replies — 11 Last Post — 01-18-2015 01:45 PM
Thread — Boondocker Turbo Pro 3D mapping test ride. Thread Starter — SNOW JW Forum — Polaris: TURBO Replies — 6 Last Post — 02-14-2011 09:35 AM
no new posts
