Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 02-28-2017, 08:13 PM
Snowspud Snowspud is offline
Currently: Not set.
Basic Member
Snowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant futureSnowspud has a brilliant future
Default New to me '01 RMK 800 prep
Long time trail sled guy here, now my first old RMK.
Its a clean "01 RMK 800. Been reading up all I can on them.
I know all the usual grease, lube, tighten stuff.
Gonna replace all fuel lines including in tank. What advice I am looking for is typical trouble spots on this model sled.
Sounds like motor mounts and water pump belt are common.
Any other typical items to get right before damage occures ?
Any place I can view on line for a service manual and jetting, clutching specs for altitudes ?
Any advice is greatly appreciated !
Rate this post: Yes | No
  #2
Old 03-02-2017, 08:41 PM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default
Do a search for crankshaft related issues on the 800 to familiarize yourself.
In a nutshell, the PTO side of the crankshaft was prone to failure around the 3000 mile mark.
Running a worn out / unbalanced primary clutch combined with inadequate engine warm ups seemed to have increased the likelihood of failure.
You can remove the primary & perform a run-out check on the outer portion of the crankshaft taper. If more than .003" you are operating on borrowed time.
Several sled engine shops, such as Indy Specialties, offered PTO bearing upgrades intended to prevent the failures.
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Summer prep mode Thread Starter — philsummers21 Forum — Snow bikes Replies — 17 Last Post — 06-30-2015 03:34 PM
Thread — freight & Prep Thread Starter — Juggs Forum — Ski-Doo: XM Sleds Replies — 17 Last Post — 01-06-2014 02:14 PM
Thread — Dealer Prep on Pro RMK Thread Starter — mud99 Forum — Polaris: Pro-Ride Replies — 11 Last Post — 10-16-2012 05:06 PM
Thread — 05 M7 season prep help please. Thread Starter — TWOSTOKED Forum — Arctic Cat Replies — 7 Last Post — 10-11-2008 06:21 AM
Thread — Sled Prep Thread Starter — 97MXZ670 Forum — General Snowmobiling Replies — 8 Last Post — 09-27-2008 08:09 PM
no new posts
