Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 02-28-2017, 09:18 AM
Boisebiker Boisebiker is offline
Currently: Living life to its fullest
Basic Member
Boisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond reputeBoisebiker has a reputation beyond repute
Default Help Phazers Down
A little back story. I was given 2 1995 Phazer II ST sleds about 2 years ago. Previous owner took great care of them but passed away. One of the sleds was built by Bender Racing with ported cylinders, different carbs and both sled have Bender pipes. While I am not new to powersports I am new to sleds. Last year while riding I burnt the piston on one sled and the Bender sled lost a wristpin clip and destroyed the cylinder. I replaced the bad cylinder on the Bender sled and was able to ride some more. The other sled stayed down because I believe it has a bad crank seal and the oil injector pump gear is shot(was running premix). This past weekend while out riding the Bender sled died. After a quick teardown I find that the lower rod bearing on the replaced cylinder is shot.
So here I am with 2 great looking, well maintained Phazers, that do not run. I am not sure I have the will to rebuild both engines. I need someone to really convince me that it is worth it to rebuild them, or even one for that matter. I have also recently run into an opportunity to buy Arctic Cat T660(non-turbo) sleds for $500 a piece. They are touring sleds used by an adventure company and were meticulously maintained. I bought 1 and rode it last week. It is no powder machine but it ran great. It even towed the phazer, myself and 4 kids about 3 miles back to the truck on Saturday without any hesitation or a burnt belt. I am considering picking up 2 more and just have fun with the kids.
Please help me decide. Either part out both Phazers or do major engine work like crank rebuild, cylinder boring, case reseal, etc. I am not sure even where to start or who can help me on the technical stuff.
Click image for larger version
ID:	281845   Click image for larger version
ID:	281846   Click image for larger version
Rate this post: Yes | No
  #2
Old 02-28-2017, 09:28 AM
Basic Member
Default
Most of my decision will stem around $$$. Are the sled worth more in parts that as running machines? What will it cost to have someone rebuild the crank? Is there a machine shop out there that is not charging an arm and leg to bore a cylinder?
And also how do I figure out why they both went down? Was it something I did or just bum luck? Sleds are being used in same location as original owner so jetting/clutch should not need changing.
  #3
Old 03-02-2017, 09:52 PM
K3 K3 is offline
Currently: Dreaming of hunting
K3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond repute
Default
I would try to fix, or buy a parts sled w/low 2K mi. or less motor @ $4 or $500 and hope to get 6K or 7K miles before boring out!!! Can not beat a GOOD old phazer IMO !!!! Hope this helps . l<>l
  #4
Old 03-03-2017, 02:05 PM
AMAX AMAX is offline
Currently: Not set.
AMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond reputeAMAX has a reputation beyond repute
Default
Good sleds but hard to justify spending too much on them. I see decent ones going for $500 - $900.
The two options for me would be sell them as is or as K3 suggested keep an eye out for a sleds with a donor motor. I don't have one but while researching old Yamaha stuff for my kids Ovation, there is a ton of info on Phazers on the net. They sold a bunch of these and a lot of guys have been keeping them going
  #5
Old 03-03-2017, 02:58 PM
stingray719's Avatar
stingray719 stingray719 is offline
Currently: 2014 Viper MTX conversion
stingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond repute
Default
Buy a beat up Phazer for the engine and put in BUT LOSE THE PIPES! Phazer ran forever stock but once you get to modding them they go boom. Old Ventures had that engine also. My brother may have parts for you and lives in southern Idaho I will message you his number
  #6
Old 03-03-2017, 03:34 PM
Basic Member
Default
Thanks for the replies. I want to keep them running because they are fun to throw around and can get me anywhere I want to go. It is just hard to drop $4-500 into a sled than will never be worth $1000. That is why I do most of my own work to keep maintenance costs down. I am pretty sure I can not do the crank job this one will need. I am contemplating tearing both down and built up 1 runner. New gaskets and seals, best pieces of both sleds and keep the other as a parts machine. I do need help deciding what parts are the best. Stock or upgraded carbs?
  #7
Old 03-03-2017, 04:06 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
If the phazers are down all we got left is the force field!
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #8
Old 03-03-2017, 04:07 PM
Teth-Air's Avatar
Default
If the phasers are down all we got left is the force field!, Better call Star Fleet!
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Teth-Air For This Useful Post:
K3 (03-03-2017)
  #9
Old 03-05-2017, 05:52 AM
motojunkie101's Avatar
motojunkie101 motojunkie101 is offline
Currently: Yamaha 4 stroke moderator
MODERATOR: Premium Member
motojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond repute
Garage
Default
If it only runs you about 500 to get them running, I'd go for it! Those sleds are great, I've been kinda keeping an eye out for one to get my son since he has outgrown his 120.
Back in the day those mod phasers were more fun than you could shake a stick at. Long track 144", custom tunnel extensions...
If you do decide to get rid of them though, let me know as I live just over the pass from you.
__________________
Quote:
Originally Posted by Himark View Post
"hold still I saw this on Snowest"
Bad decisions make good stories
2015 Yamaha Viper 162 SE/MPI turbo
Days until I retire
  #10
Old 03-07-2017, 09:04 AM
Basic Member
  #11
Old 03-09-2017, 05:13 AM
Garage
Click Here to Register
  #12
Old 03-17-2017, 07:56 AM
Basic Member
  #13
Old 04-05-2017, 08:11 AM
Basic Member
  #14
Old 04-08-2017, 03:33 PM
eddy's Avatar
eddy eddy is offline
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
  #15
Old 11-10-2017, 03:55 PM
Basic Member
  #16
Old 11-12-2017, 05:32 PM
Garage
  #17
Old 11-13-2017, 03:57 PM
Basic Member
  #18
Old 11-13-2017, 04:01 PM
Basic Member
  #19
Old 11-14-2017, 09:53 AM
Blk88GT's Avatar
Blk88GT Blk88GT is offline
Currently: Patiently waiting for my '19
Blk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond repute
  #20
Old 11-21-2017, 11:25 AM
Basic Member
  #21
Old 11-22-2017, 11:54 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
  #22
Old 12-07-2017, 04:28 PM
K3 K3 is offline
Reply
Bookmarks
Tags
phazer, t660
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Phazers ? Thread Starter — schleman Forum — Yamaha: 4-Stroke Replies — 4 Last Post — 10-31-2012 11:36 AM
Thread — yamaha phazers Thread Starter — Sidney500 Forum — Yamaha: 4-Stroke Replies — 1 Last Post — 01-07-2011 07:23 PM
Thread — Old Phazers Thread Starter — (POWDER) Forum — General Snowmobiling Replies — 26 Last Post — 02-20-2009 10:22 AM
Thread — 95 and 96 Phazers 4 sale Thread Starter — Freak Forum — Yamaha (Swapmeet) Replies — 2 Last Post — 11-25-2008 12:01 AM
no new posts
