Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 02-24-2017, 01:57 PM
Buried Buried is offline
Currently: Not set.
Buried is an unknown quantity at this point
Default Sometimes won't start after shutting off
Have a 2016 M8000 with Boondocker Pro-Boost turbo. Seems like once or twice a day I'll shut it off and when I try to start it, it won't start.
So I unhook the Fuel pump wires and do the 9 volt battery trick. Try it again. If still nothing, I unhook the temp sensor, pull the rope a couple times. Reinstall temp sensor and pull.
Usually it'll start. If not, I start the process over and it starts.
Just wondering if anyone has any insight? When it was N/A it would do this too, but I got by, by pulling the rope a few times and it would eventually fire.
Could it be just heat soak? TIA
Rate this post: Yes | No
  #2
Old 02-24-2017, 02:58 PM
Goin For Snow's Avatar
Goin For Snow Goin For Snow is offline
Currently: Waiting for snow
Goin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond reputeGoin For Snow has a reputation beyond repute
Default
there seem to be some issues like this out there. One of my 15 M8's seems to do this. Its bone stock, except a tether cord. It would die and sometimes it would restart for just a moment. I found that by giving a couple of drips of gas in the cylinder it would fire right up. Its like there isn't enough charge to keep the fuel pump running when pulling it over and the running for a moment longer will keep it running. Doesn't explain however why it does it in the first place.The fuel pump assembly is kind of spendy. I have been reading more 16's it seems doing it than 15's. ITs never in the morning when its cold. Always when it is being ridden, plugs are bone dry when i take it out after pulling it over several times. . My other 15 has never done or even hiccuped.
  #3
Old 03-18-2017, 11:53 PM
HCR10 HCR10 is offline
Currently: 2016 cat turbo and 2013cat turbo for her
HCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond repute
Default
Call dale at cutlers and he can get you a hot start switch that you flip when this happens. My boondocker did the same thing and the switch fixed the problem 100% Dale does this on all his turbo sleds and it comes as a standard part in his kit sense 2010 because the turbo amplifies the problem.
  #4
Old 03-28-2017, 02:21 PM
whpdmw whpdmw is offline
Currently: On cloud 925
Basic Member
whpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond reputewhpdmw has a reputation beyond repute
Default
One thing that has helped with my sleds is to let them idle a little longer before I hit the kill switch.
  #5
Old 03-28-2017, 03:22 PM
007's Avatar
007 007 is offline
Currently: ready
007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute007 has a reputation beyond repute
Default
I know I will catch some flack about this but when I ran a boondocker controll box I had the same issue and I had a hotstart switch. I carried a small bottle of starting fluid with me. All it took was a little squirt in the air snorkel and away I went. Use in small amounts and you wont have a problem.
Since I went to a PCwBoost and the problem went away.
__________________
KJP
"its bad luck to be superstitious"
  #6
Old 03-30-2017, 08:03 AM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
Quote:
Im trying to understand this hot start switch thing I have two cutler set ups here and they both have them i have my own turbo set up that i built and never have any issue like this. So whats happening here that it stakes this hot start switch to start?
__________________
M 1000 modded but no turbo no way Uh well maybe
  #7
Old 03-30-2017, 10:31 AM
knifedge knifedge is offline
Currently: Not set.
knifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond reputeknifedge has a reputation beyond repute
Default
Both my stock'16's did this last weekend warm day after hillclimbing......plugs were dry, put gas in cylinder, then it would start.....someone posted airbox temp sensor gets hot so unplug it to start...yet to try myself...maybe just do a cool down lap.....
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2006 M8 won't start after shutting off Thread Starter — prichert Forum — Arctic Cat: M Series Replies — 2 Last Post — 12-30-2014 11:34 AM
Thread — Cant start after shutting off Thread Starter — catfreeride Forum — Arctic Cat: Proclimb M Replies — 24 Last Post — 01-15-2014 08:53 PM
Thread — 10 M8 won't start Thread Starter — AKRMK05 Forum — Arctic Cat: M Series Replies — 21 Last Post — 01-24-2010 01:57 PM
Thread — Won't start!!!???? Thread Starter — 4wheeler Forum — Ski-Doo: REV Sleds Replies — 7 Last Post — 01-08-2010 06:46 PM
Thread — 09 D8 won't start, need some help Thread Starter — ENDO1 Forum — Polaris Replies — 9 Last Post — 03-06-2009 07:58 PM
no new posts
