Upgrade to Premium
Member Sled Builds A forum for building a project or mod sled.... Not just your common "Mods", but full on sled build projects.
Reply
  #1
Old 02-18-2017, 11:19 AM
HARDWARE HARDWARE is offline
Currently: Not set.
Basic Member
HARDWARE is an unknown quantity at this point
Default Why clutches
As I read through the member builds it comes up a lot the issues of packaging a machine with 2 huge cvt clutches?? Why not an electronically shifted gear box? I have a Honda SxS with a electronically shifted gear box? I keep wondering about a maching built with a 500cc ish motorcycle engine factory turbo 115 hp ish?
Flame away sno westies!!
Rate this post: Yes | No
  #2
Old 02-18-2017, 11:33 AM
joshkoltes's Avatar
joshkoltes joshkoltes is online now
Currently: TOO MANY PROJECTS!
joshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond reputejoshkoltes has a reputation beyond repute
Garage
Default
Its weight size and the amount of shifting would destroy them
And side by sides suck
__________________
Snow
  #3
Old 02-18-2017, 11:37 AM
Currently: Not set.
Basic Member
Default
Works for sno bikes so far?
  #4
Old 02-18-2017, 01:01 PM
joshkoltes's Avatar
Garage
Default
Well then you should go and design one for a sled and sell it to the manufactures.
I suppose it would need a chain drive off the pto of the crank that would locate this gear box somewhere between the intake and the fuel tank then another drop case from the output down to the drive shaft. To make it do able your going to need the gearing to be light as possible probably all gears custom recut but then it'll only handle the power of a scooter.
I think someone tried this years ago by the way. Difference was they just used a crotch rocket engine and trans but it never really worked
Pretty sure it was cpt. Ron on here
__________________
Snow
  #5
Old 02-18-2017, 06:11 PM
d1100t's Avatar
d1100t d1100t is online now
Currently: Looking forward to the first ride on my 2018 M 800 CTEC
d1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond repute
Default Chain drive.
I think your right.
Capt. Ron had or still has a Honda turbo powered sled that is/was chain driven.
If I remember correctly there was another sled built using a 1300 Suzuki street bike engine. I'm guessing it was chain drive also.
  #6
Old 02-18-2017, 09:55 PM
Currently: Not set.
Basic Member
Default
I am thinking a MC power plant gear box and all rekluse style clutch push button electric shift or auto,chain to track shaft with a sprocket rotor ,combo turbo bolted to the head on front of motor inter cooled , steering post over top of motor , could be narrow enough to straddle the motor? More of a snow bike turned snowmobile!
Again flame away westies!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Clutches Thread Starter — 670mod Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 02-04-2014 09:24 AM
Thread — cat clutches 6 tower 9 tower and skidoo tra clutches Thread Starter — wyoradcat Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 3 Last Post — 12-19-2013 01:03 PM
Thread — clutches Thread Starter — julio Forum — Arctic Cat: 1100 ProClimb Replies — 9 Last Post — 04-21-2013 10:24 PM
Thread — Clutches Thread Starter — smokin800 Forum — Arctic Cat: M Series Replies — 3 Last Post — 02-10-2010 09:53 AM
Thread — TEAM Clutches, Helix's, and CAT clutches Thread Starter — stephenclark Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 02-01-2008 10:35 AM
no new posts
