Upgrade to Premium
Reply
  #1
Old 02-18-2017, 10:35 AM
wood51282 wood51282 is online now
Currently: Not set.
Basic Member
wood51282 is an unknown quantity at this point
Default 2017 King Cat vertical steering post
Has anyone installed a vertical steering post on the new king cat? If so, will the kit for the 1100 fit?
Rate this post: Yes | No
  #2
Old 02-20-2017, 02:41 PM
Bacon Bacon is offline
Currently: Paneling out
Bacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond reputeBacon has a reputation beyond repute
Default
I'm not so sure it needs verticle steering as much as just a taller riser. The factory one is short. And a lower seat. It's like riding with a big fat pillow between your legs.
  #3
Old 02-21-2017, 07:51 AM
2013 M1100 Turbo 2013 M1100 Turbo is offline
Currently: Not set.
Basic Member
2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute
Default
What Bacon said.....I ended up putting a 6.5" riser in place of the 4.5" riser it came with. I didn't like being hunched over while riding standing up.
Along with that I think the steering support structure is slightly different on the King Cat, so I don't know if the bolt on supports for the vertical post will line up right. I have not checked this however, just some thoughts.
  #4
Old 02-25-2017, 09:24 PM
127x 127x is offline
Currently: Not set.
127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute127x has a reputation beyond repute
Default
I've done it ready
Order all the parts off 2016 m7000
Works great
Cut hole by were your recoil handle would be for the bottom two bolts
Took bout 2.5 hrs
Hands down better then standard steering
Not even close how better the sled handles
  #5
Old 02-28-2017, 09:55 AM
Currently: Not set.
Basic Member
Default vertical steering
Thank you for the reply.
  #6
Old 03-01-2017, 08:59 PM
SnowJam SnowJam is offline
Currently: Not set.
Basic Member
SnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond reputeSnowJam has a reputation beyond repute
Default
Quote:
Originally Posted by 127x View Post
I've done it ready
Works great
Took bout 2.5 hrs
Sounds good mod. Got some pic of the set up?
  #7
Old 12-19-2017, 10:47 PM
nw-sickboy nw-sickboy is offline
Currently: Not set.
nw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond reputenw-sickboy has a reputation beyond repute
Default
Finishing this up tonight. It’s definitely possible - I ended up using parts from kit and from the 2016 like was mentioned above. I’ll post more details/pics later. Feels like it puts bars in a great position.
  #8
Old 12-26-2017, 10:09 PM
Currently: Not set.
Default
I finished his last week. I ordered the kit from that was offered from 12-15 and the parts from the 16 hcr (poster above stated the year model) - the single post Bay the gas tank is a better fit
From 16 model ó the dual post would
Work from either. The kit or parts from a 16 will work. Iím pretty sure youíll need to stack a few washers if you use the kit to make the single support tall enough.
Disregard the switches - ordered these for my mountain cat and love them - ordered them for the kin cat and ..... they donít work - ha - should have read the listing a little closer.
Click image for larger version
The Following User Says Thank You to nw-sickboy For This Useful Post:
Woody67 (12-27-2017)
  #9
Old 01-08-2018, 09:20 AM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default
Anyone have any pictures or details for doing the vertical steering post on a 2014 m9000?
Still not really sure how this modification works?
  #10
Old 02-08-2018, 04:32 PM
scoboe scoboe is offline
Currently: Not set.
Basic Member
scoboe is an unknown quantity at this point
Default
Is this the kit you guys are using?
https://www.countrycat.com/arctic-ca...1100-5000-9000
Thanks!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — king cat cr steering post, risers Thread Starter — skidoomutt Forum — Handlebars/Risers (Swapmeet) Replies — 2 Last Post — 04-05-2012 07:40 PM
Thread — stock king cat steering post Thread Starter — oldschooldoo Forum — Handlebars/Risers (Swapmeet) Replies — 0 Last Post — 10-21-2010 07:55 PM
Thread — 1M/King cat steering post.. Thread Starter — Metso Forum — Arctic Cat: 1M Replies — 7 Last Post — 07-19-2010 11:24 AM
Thread — !!! Bent Steering Post 04 King Cat !!! Thread Starter — sledderdone Forum — Arctic Cat: 1M Replies — 10 Last Post — 01-26-2010 03:47 AM
Thread — King cat steering post Thread Starter — The Big Kid Forum — Arctic Cat: 1M Replies — 7 Last Post — 12-18-2008 08:48 AM
no new posts
