Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 02-14-2017, 12:56 PM
bigcrash24 bigcrash24 is online now
Currently: Training 9yr old to ride!
Basic Member
bigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond repute
Default 98 MM overheated: icy trails
Took it out on Sunday, trails were icy/hard compact snow. Warm outside, guessing about 40F.
Let the sled warm up for about 10min before riding.
Got up the trail for about 2miles, showed overheat.
Opened the hood, coolant reservoir was just starting to overflow out the spout.
Exchangers were warm/hot.
Not using ice scratchers.
Thinking that there was just not enough snow to get onto the exchangers.
I've never had a problem with this sled before, but I've never run it on hard/icy snow trails either.
Anyone else?
I've ordered ice scratchers, so will try it out again and see.
(I was also running my 2001 MM with ice scratchers and it did fine (temp gauge showed about 120-130).
Rate this post: Yes | No
  #2
Old 02-14-2017, 03:45 PM
trail traveler trail traveler is offline
Currently: Not set.
trail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond reputetrail traveler has a reputation beyond repute
Default
You're right on target about needing ice scratchers. When the trails are compact like you described, ice scratchers will certainly do the job. When I'm out riding and I see my temps climb, I'll drop my scratchers and the temperture will drop about 20 degrees in under a minute of riding.
The Following User Says Thank You to trail traveler For This Useful Post:
bigcrash24 (02-14-2017)
  #3
Old 10-13-2017, 09:28 PM
tacoman tacoman is offline
Currently: Not set.
Basic Member
tacoman is an unknown quantity at this point
Default Same problem.
I have the same sled with the same problem. Going up a long hill on compact snow will make it overheat. If possible plow through some soft snow on the side of the trail.
The Following User Says Thank You to tacoman For This Useful Post:
bigcrash24 (12-07-2017)
  #4
Old 12-15-2017, 12:38 PM
LoneViper LoneViper is offline
Currently: Not set.
LoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond repute
Default
If you run into a real problem, pack the tops of the running boards with chunks of snow then head for the first soft spot you see.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — how icy will stampede pass be this weekend? Thread Starter — spidermonkey Forum — Washington Replies — 13 Last Post — 12-12-2013 02:39 PM
Thread — High winds, icy ridges and a faceplant... still better than work -Pics Thread Starter — fourthmeal Forum — General Snowmobiling Replies — 26 Last Post — 02-24-2011 07:49 AM
Thread — Icy Highways and the Value of Life. Thread Starter — ak49er Forum — Alaska Replies — 44 Last Post — 12-18-2009 08:21 PM
Thread — Lost RPMS on Hard pack icy Trail(Caused By Heat?) Thread Starter — Adobe-Al Forum — Polaris Replies — 13 Last Post — 02-11-2009 11:10 PM
Thread — What it's like to drop into the icy butt-crack Thread Starter — revpilot Forum — General Snowmobiling Replies — 3 Last Post — 12-21-2008 09:06 PM
no new posts
