Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 02-12-2017, 12:37 PM
Mnt.Tamer Mnt.Tamer is online now
Currently: Dreaming of powder
Basic Member
Mnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond reputeMnt.Tamer has a reputation beyond repute
Default Need help with 04 900 carbs
04 mountain cat motor as it sits it starts to fill the motor with fuel and smells like raw fuel. The float bowls look fine and very clean what do I look for? Also looking for a after market can one that is fairly quiet. Thanks
Rate this post: Yes | No
  #2
Old 02-12-2017, 04:01 PM
Readymedic's Avatar
Readymedic Readymedic is online now
Currently: How is 18/19 lookn'??
Readymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond reputeReadymedic has a reputation beyond repute
Default
One problem that I came across with the 900 I had and I now have another one, is the choke plungers. If you change your choke cables, they are a pain to set. If they are not right they will flood the engine instantly. The trick is too have it running then turn the nuts on top once it is running correctly. If it has the original cabels, the rubber seats on the plunger maybe worn out or even deteriorated too.
I have filled the crank case many a time.
Good luck.
For a quiet can, SLP.
  #3
Old 02-12-2017, 11:10 PM
Basic Member
Default
Thanks for the tip of will look into it. That's funny that you say SLP for a quiet can that what I have and it's loud as heck. After talking to Dale cutler he thinks when I ordered the can from slp they shipped me a race can instead of the trail can.
  #4
Old 02-13-2017, 10:05 AM
Idcatman1's Avatar
Idcatman1 Idcatman1 is offline
Currently: Not set.
Idcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond repute
Default
If it is flooding while running it could be the choke adjustment. Other possibilities are something caught in the fuel inlet needle in the carb float bowl or stick floats, both of which would keep the needle from closing when the fuel level in bowl gets to the right level. If it is flooding while not running it is likely a broken diaphragm in the fuel pump.
  #5
Old 02-13-2017, 03:09 PM
Basic Member
Default
Yes it's flooding while not running, so you think a fuel pump issue? I will take it apart and look . Thanks
  #6
Old 02-13-2017, 09:22 PM
Readymedic's Avatar
Default
It wouldn't be a fuel pump issue because you need a running motor to work the fuel pump. The fuel pump runs off of the impulse line from the bottom of the crank case.
It could be the needle and seat might possibly be stuck too. But when they stick, the floats hang down so the seat will be open allowing fuel to flow.
Rip down the carbs and clean them . I would start with the choke plungers.
  #7
Old 02-13-2017, 10:15 PM
Idcatman3's Avatar
Idcatman3 Idcatman3 is offline
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
If the diaphragm in the fuel pump is torn, fuel will gravity feed through the pump and impulse line into the crankcase. It's rare with these pumps, but not unheard of. It's the only thing I can think of that would cause it to fill up while not running.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
  #8
Old 02-13-2017, 10:49 PM
mattymac's Avatar
mattymac mattymac is offline
Currently: investing in lead
mattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond reputemattymac has a reputation beyond repute
Default
put new orings in the plastic needle and seat assembly, take out the two screws that hold the whole assembly to the carb in the bowl, new oring and it'll be good to go. Ive done literally dozens of these, pressure tested before and after... The oring is the problem, the ethanol in the fuel breaks down the rubber oring causing it to go flat/soft or simply break.
It will siphon from the tank while sitting, but be even worse when running/pumping fuel.
__________________
1200 WC triple
1500 cat triple
impulse apex
900 VE cat
"hey your ski is under your belly pan!"
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to mattymac For This Useful Post:
sledmasterr (02-14-2017)
  #9
Old 02-14-2017, 08:37 PM
sledmasterr sledmasterr is offline
Currently: Not set.
Basic Member
sledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond reputesledmasterr has a reputation beyond repute
Default Yep
Mattymac isn't absolutely correct, seen it many times myself.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — ZR 800 or 900 Carbs Thread Starter — GroundPoundinMotorsports Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 2 Last Post — 03-09-2010 04:51 PM
Thread — ac 900 carbs Thread Starter — W.W.S.D Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 1 Last Post — 11-01-2009 10:29 PM
Thread — 04 900 KC carbs Thread Starter — ruedstat Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 2 Last Post — 09-06-2009 07:23 PM
Thread — ac 900 carbs Thread Starter — Tractor Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 05-15-2008 10:08 PM
no new posts
