Upgrade to Premium
Reply
  #1
Old 02-06-2017, 04:27 PM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default Front feels way to heavy!
New here to snowest, please bear with me so I'll explain what I got going on and see if I can find help.
Not new to sleds but new to the 4s turbo. I have a 2014 M9000 Ltd, all stock.
Front shocks were at like 150 psi, way too high.
Stock skis, I know they blow...
Rear float was at 150 psi as well and I am not really sure on preload for front rear skid shock.
Sled handles like **** and I have all I can do to turn the thing... Help me understand what I need to do to make this machine feel somewhat fun to ride.
As of right now, I want it gone and I'm going to a pro rmk!
Rate this post: Yes | No
  #2
Old 02-06-2017, 05:06 PM
89sandman's Avatar
89sandman 89sandman is online now
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
Default
The front feels heavy because it is. I'd start by stiffening the front track shock and putting some of that weight to the skid and soften the rear track shock to help it transfer it to the rear. This will lighten the front but also cause it to trench more. Drop the pressure in the front ski shocks that will help it roll more and a little easier to turn.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 02-06-2017, 05:23 PM
Currently: Not set.
Basic Member
Default
Thanks for that info. I also read on here that going to the 16 model year a arms and spindles helps lot.
I love the power but like I stated the handling is terrible. Maybe I'm trying to do the wrong type of riding? Powerline and backwoods and really I need to get this sled in 7 feet of snow at 9000k elevation?
  #4
Old 02-06-2017, 05:50 PM
89sandman's Avatar
Default
I spent most of a season riding a four stroke because my main riding buddie decided to buy one and he could just not ride it. Things are tough all around for any tight technical riding. They want to head into every treewell, off camber situations are rough, sidehilling becomes a fight for your life sometimes. Unless you are riding open rolling areas or point and shoot you are gonna have to use quite a bit more effort and energy than your buddies on a 2 stroke. Instead of it reacting to your input it's almost like you are fighting with your wife trying to get her to do what you want
The Following User Says Thank You to 89sandman For This Useful Post:
RickM (02-07-2017)
  #5
Old 02-06-2017, 07:15 PM
Currently: Not set.
Basic Member
Default
OK... When you put it like that I understand. It's going to do what it wants anyways. I guess by tighting up the front skid shock, will that help that much? I honestly don't care about trenching, I like in Upper MI, so 3 to 4 of snow is max for me... I just want to be able to steer the thing. Like my original thoughts where if this thing was this hard to steer from factory how did they sell any?? Sure, at 301kg (663lbs), it's considerably heavier then anything else out there but I didn't think it would be this bad.
  #6
Old 02-06-2017, 09:45 PM
89sandman's Avatar
Default
Think of your sled as a teeter/totter and the front track shock is in the center. With the front track shock stiffened it puts more weight in the middle and less off the front and rear. Lessening the pressure in the rear track shock lets the sled tip towards the rear of the sled taking weight off the front ski's. When you give the sled throttle inertia causes weight to go towards the rear, with a stiff front track shock and a loose rear shock it allows the weight from the front of the sled to "transfer" to the rear. Well not actually the weight but where the weight is supported.
  #7
Old 02-07-2017, 03:50 AM
WyoBoy1000's Avatar
WyoBoy1000 WyoBoy1000 is offline
Currently: Working,
WyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond reputeWyoBoy1000 has a reputation beyond repute
Default
How to fix,
Sell it, but an m8000, make a few changes and ride circles around the pro.
4 strokes are the dumbest thing on the snow. I can still make them do crazy stuff but why. I hate them with a passion.
__________________
Shhhh, its a secret
Assume = when you as$,u,me you make an as$ out of u and me. Think, ask, get the facts and then go forward.
  #8
Old 02-07-2017, 07:12 AM
bigrig bigrig is offline
Currently: Not set.
bigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond reputebigrig has a reputation beyond repute
Default
I ride one too. It's very heavy! Loose that muffler, replace skis, tallest riser you can grab. Drop air in rear, will help shift that weight. Other stuff helps a little.... Sled will always be heavy, you will learn to ride it. Every ride is a challenge! But squeeze right hand, be rewarded!!!
  #9
Old 02-07-2017, 11:04 AM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
I don't think anyone mentioned ski alignment. Check your ski alignment and make sure it is within spec, slightly toed out (1/8"). If the skis are toed in, or too far out, they will be difficult to steer.
  #10
Old 02-07-2017, 11:59 AM
KMMAC KMMAC is offline
Currently: KEEP AN EYE OPEN WHILE YOU SLEEP
KMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond repute
Default Front skid arm
It was recommended that I lower the front skid mounting point on my
M1000 to lighten the front, is it possible to do the same on these 4 strokes?
  #11
Old 02-07-2017, 08:10 PM
d1100t's Avatar
d1100t d1100t is online now
Currently: Towing another Polaris 850 behind my Cat
d1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond reputed1100t has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to d1100t For This Useful Post:
Nickhagen1 (02-08-2017)
  #12
Old 02-07-2017, 08:19 PM
d1100t's Avatar
  #13
Old 02-07-2017, 09:19 PM
blackjack85335 blackjack85335 is offline
Currently: Love my M1100
blackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond repute
The Following 5 Users Say Thank You to blackjack85335 For This Useful Post:
bigrig (02-08-2017), d1100t (02-07-2017), JustBoostIt (04-17-2017), kuart (02-09-2017), Nickhagen1 (02-08-2017)
  #14
Old 02-08-2017, 09:50 AM
leadfoot33 leadfoot33 is offline
Currently: modding proclimb
leadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond repute
  #15
Old 02-08-2017, 02:24 PM
PISTONPETE's Avatar
PISTONPETE PISTONPETE is offline
Currently: Wrenching
PISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond repute
  #16
Old 02-08-2017, 02:53 PM
Sharp Sharp is offline
Currently: Not set.
Basic Member
Sharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond reputeSharp has a reputation beyond repute
  #17
Old 02-08-2017, 05:19 PM
jeffheart153 jeffheart153 is offline
Currently: Not set.
Basic Member
jeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond repute
The Following 2 Users Say Thank You to jeffheart153 For This Useful Post:
blackjack85335 (02-11-2017), kuart (02-09-2017)
  #18
Old 02-09-2017, 10:45 AM
busken busken is offline
Currently: Not set.
Basic Member
busken is an unknown quantity at this point
  #19
Old 02-09-2017, 01:17 PM
Currently: Not set.
Basic Member
  #20
Old 02-09-2017, 04:46 PM
WyoBoy1000's Avatar
Currently: Working,
  #21
Old 02-10-2017, 01:02 PM
Currently: Not set.
Basic Member
  #22
Old 02-10-2017, 02:48 PM
2013 M1100 Turbo 2013 M1100 Turbo is offline
Currently: Not set.
Basic Member
2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute
  #23
Old 02-12-2017, 10:56 PM
dopey333 dopey333 is offline
Currently: Not set.
Basic Member
dopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant futuredopey333 has a brilliant future
  #24
Old 02-13-2017, 09:12 AM
Motorbreath_ Motorbreath_ is offline
Currently: Loving my Summit 850!!
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
The Following User Says Thank You to Motorbreath_ For This Useful Post:
bigrig (02-13-2017)
  #25
Old 02-13-2017, 10:57 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Heavy front end Thread Starter — large52 Forum — Polaris: 900 Replies — 7 Last Post — 12-19-2010 11:24 AM
Thread — Sled feels too heavy Thread Starter — Dexterdog Forum — Arctic Cat: M Series Replies — 19 Last Post — 01-29-2010 09:27 PM
Thread — Heavy front springs Thread Starter — 800edgexc Forum — Polaris: EDGE Replies — 0 Last Post — 01-03-2010 09:31 PM
Thread — Front end feels heavy... Thread Starter — carman_65 Forum — Polaris: EDGE Replies — 8 Last Post — 12-13-2009 07:58 PM
Thread — xp front end heavy Thread Starter — Miss RMK Forum — Ski-Doo Replies — 44 Last Post — 01-12-2009 10:33 PM
no new posts
