Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 02-05-2017, 07:26 PM
ZX Guy's Avatar
ZX Guy ZX Guy is offline
Currently: Not set.
ZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond reputeZX Guy has a reputation beyond repute
Default Seal for crank on clutch side
01 800 summit idle's high and takes a long time to idle down. Was thinking seal on crank clutch side ? Any ideas
Rate this post: Yes | No
  #2
Old 02-05-2017, 07:53 PM
lancelarue lancelarue is offline
Currently: waiting for snow!!
lancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond repute
Default idle
Wd-40 around crank seal. If it doesn't respond:
Try turning idle screw down first. If that doesn't do it, ( you'd be amazed how many times that's cured it!) fatten up fuel screws 1/4 turn.
Check your carb sync. I'd be amazed if those old carbs were anywhere close!
If it doesn't hang/idle for at least 5 to 10 seconds after it is hot and cleaned out good, you're too fat on the fuel screws anyway.
__________________
Old faithful :06' Summit X W/163" flex,2 wheels in rear, big drop & roll. 860R, 05' electronics, 46 mm Lectrons, custom airbox, lots of air, SLP single, Paragon, Mtn Tamer rear w/ floats all the away around,extra cooling tubes in tunnel, premix, 5 gal race tank, >
Trail sled: 07' 151" stock except 860 & paragon, other stuff
  #3
Old 02-06-2017, 10:42 AM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Default
My guess would be gummed up pilot circuit or cracked reed boots. Or as suggested above, open fuel screws a bit.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Changing pto side crank seal Thread Starter — MSP381 Forum — Ski-Doo: S-2000 and older Replies — 2 Last Post — 12-14-2016 03:53 PM
Thread — Mag Side Crank Seal Thread Starter — Mech Engr Forum — Polaris: 900 Replies — 5 Last Post — 04-20-2014 08:21 PM
Thread — changing PTO side crank seal Thread Starter — fullboredragon Forum — Polaris: Pro-Ride Replies — 4 Last Post — 02-08-2013 04:24 PM
Thread — Clutch Side Crank Seal Replace Thread Starter — mac Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 12-04-2009 03:32 PM
Thread — mag side crank seal Thread Starter — ullose272 Forum — Polaris: EDGE Replies — 5 Last Post — 09-19-2009 12:37 PM
no new posts
