Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 01-30-2017, 10:08 AM
jakey-boy jakey-boy is online now
Currently: Not set.
jakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond reputejakey-boy has a reputation beyond repute
Garage
Default Removing Stinger from stock PIPE for turbo applications
Wondering how many of you guys have done this? Sounds like it is part of the install for a cutler kit but have people tried it with other kits? Mostly wondering if it changed your fuel numbers to do it? Thinking about giving it a try to clean up the bottom end on my sidekick but with no way to monitor air fuel or change tuning I want to have an idea what I am getting into prior.
To me it makes sense why we are having some trouble on the bottom with these kits if there is too much back pressure.
__________________
TheJKYboy
Click here for Awesome Sled Pics!!!
Rate this post: Yes | No
  #2
Old 02-24-2017, 01:19 PM
rusty rider rusty rider is offline
Currently: rtr
rusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond reputerusty rider has a reputation beyond repute
Default
Yes, get rid of stock stinger. Most kit builders don't do it because it makes install more difficult for the average guy who just wants to bolt up something then take off and sell sled as a stocker at end of season.
0 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 03-01-2017, 06:52 PM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
I built my own kit and put a 2 inch stinger in my stock pipe it uses the king cat grafoil seal
__________________
M 1000 modded but no turbo no way Uh well maybe
  #4
Old 03-17-2017, 10:53 AM
jpokryfki jpokryfki is offline
Currently: Not set.
jpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond reputejpokryfki has a reputation beyond repute
Default
Can someone post some pictures of this? And what size and length of 90deg bend I would need? Thanks.
  #5
Old 03-18-2017, 11:47 PM
HCR10 HCR10 is offline
Currently: 2016 cat turbo and 2013cat turbo for her
HCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond repute
Default
Go to cutlers cox web site and go to instructions you will see tbe instructions to do this to the stock pipe. Its easy took me 2 hours start to finish and you do not need to make/buy another stinger you reuse the stock one.
  #6
Old 03-18-2017, 11:48 PM
Default
Cutlers cpcracings web site
  #7
Old 03-27-2017, 09:50 AM
Currently: Not set.
Garage
Default
Forgot about this thread. I did this a couple months ago even before I could get feedback on here. Definitely was worth it helped my bottom end a fair amount. I feel like the sled had so much back pressure it was choking until the exhaust valves could open.
Really easy to do just have to be proficient welding.
__________________
TheJKYboy
  #8
Old 09-24-2017, 09:00 PM
Tyshu2's Avatar
Tyshu2 Tyshu2 is offline
Currently: Modifying.......
Tyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant futureTyshu2 has a brilliant future
Default
Just thought I would share how I like to remove stinger with minimal welding.
Measure back 5 and 6 inches. Use thin kerf wheel, plunge cut in middle of the weld. This removes weld on inner support. Grind weld where chamber meets pipe enough to free the pipe. Gently twist with pipe wrench to break inner support free. Use jig saw to remove tabs through slot. With tabs removed pull pipe out as far as possible and cut off. This small inner piece that had the support bracket is removed from other end of exhaust pipe. You can see how jig saw blade removed tabs on the interior of the stinger to allow extraction from the other end of the pipe. Weld 2 slots shut and clean off any weld spatter on the inside. (I use a piece of metal as a backer for welding the 2 slots in case of a burn through, that is what the vise grips are holding, then remove the backer metal). Then cut stinger to length and weld in place, leak test and clean and paint and you're done. I am doing a boondocker pro boost from BDX and the pipe needs to modified to fit. This is a nice kit and top components with MTA and TIAL.
Hope this idea helps because it minimizes welding and keeps the interior of the pipe clean. Remember..... anything in the pipe will get blown through the vanes so keep it clean!
Click image for larger version
ID:	285834   Click image for larger version
ID:	285835   Click image for larger version
ID:	285837   Click image for larger version
ID:	285838   Click image for larger version
ID:	285840   Click image for larger version
ID:	285841   Click image for larger version
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #9
Old 12-06-2017, 08:13 AM
Tyshu2's Avatar
Default
Just another pic to help understand what is being cut with thin kerf 4" wheel. And tabs to cut off with jigsaw blade
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Engine damage when stinger fails on stock pipe Thread Starter — hivoltagesledhead Forum — Ski-Doo: TURBO Replies — 70 Last Post — 04-07-2011 05:40 PM
Thread — Performance Polaris Cfi Cylinder Heads for Turbo and Non-Turbo applications Thread Starter — 1200psi Forum — Polaris: IQ Replies — 35 Last Post — 11-11-2010 02:04 PM
Thread — Inverted stinger in the stock pipe. Thread Starter — nuttyn01 Forum — Ski-Doo: TURBO Replies — 0 Last Post — 02-02-2010 09:28 PM
Thread — Removing the shield on stock pipe Thread Starter — Flatbed Forum — Ski-Doo Replies — 16 Last Post — 03-30-2008 09:48 AM
Thread — Stinger ID on stock m1000 and M8 pipe Thread Starter — mrquick68 Forum — Arctic Cat Replies — 4 Last Post — 03-10-2008 11:54 PM
no new posts
