Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 01-30-2017, 07:10 AM
Barcode's Avatar
Barcode Barcode is offline
Currently: Spoon!!!
Barcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond repute
Default New idea for battery replacement save weight
Maybe not new idea, but for sleds maybe. We've been testing this setup this season so far. Its been pretty flawless. There is some time needed to fit the two components and wire them together but in total the weight savings is good and for not super high dollars. Considering the EarthX battery we were running weighed in at 4lbs this set up came in at 2.88lbs for about the same price as the EarthX battery.
The main reason we looked into this idea, is the Viper seems to be plagued with a voltage issue. If it wasn't good and strong, its would do all kinds of crazy things.
Super Capacitor http://www.mouser.com/ProductDetail/...BssI7LKw%3d%3d
hobby battery https://hobbyking.com/en_us/zippy-fl...epo4-pack.html
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to Barcode For This Useful Post:
jeffheart153 (02-02-2017), LPIdaho (01-31-2017), Snowmixer (02-02-2017)
  #2
Old 01-30-2017, 11:49 AM
stingray719 stingray719 is offline
Currently: 2014 Viper MTX conversion
stingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond repute
Default
Interesting, I assume the battery charges the cap for a boost to start? Any chance of a quick wiring diagram?
  #3
Old 01-30-2017, 12:21 PM
christopher's Avatar
christopher christopher is offline
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default
This one will be interesting to follow along...
__________________
  #4
Old 01-30-2017, 03:02 PM
Barcode's Avatar
Currently: Spoon!!!
Default
Quote:
Plus to plus. ground to ground. Nothing tricky. The battery is to keep the Super cap charged.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Barcode For This Useful Post:
stingray719 (01-30-2017)
  #5
Old 01-31-2017, 11:19 AM
LPIdaho's Avatar
LPIdaho LPIdaho is offline
Currently: Working hard!
LPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond reputeLPIdaho has a reputation beyond repute
Default
Could you do it without a battery and have the sled charge it?
So you would have to pull start the first time of the day, but then after that the capacitors would have enough charge to run the electric start?
__________________
  #6
Old 01-31-2017, 11:51 AM
Barcode's Avatar
Currently: Spoon!!!
Default
Sure, the Super caps charge very quickly. And do hold the charge for a good while. Just not two weeks. For the day you'd be great once there charged.
  #7
Old 01-31-2017, 01:10 PM
swrev swrev is offline
Currently: Turbo XP
swrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond reputeswrev has a reputation beyond repute
Default
Like it. I run an EVO2 4 cell ballistic (weighs less than a pound) on my turbo Skidoo XP and use it with the starting relays to prime my fuel system. Carb turbo roll overs can still be a pain to start. W/ this setup, I could put my starter back on w/ out the weight penalty of a bigger battery. The little Evo does not have enough to do the job by itself.
You mentioned you could get away w/out a battery. Have you tried starting just off the capacitor w/out a battery also wired in line to see if the cranking amps really did hold up or cold start well?
Thanks
  #8
Old 02-01-2017, 05:48 AM
Barcode's Avatar
Currently: Spoon!!!
Default
Havent tried it yet. Just been using both. I will give that a try next time were out.
swrev (02-01-2017)
  #9
Old 02-01-2017, 09:58 PM
SNWMBL SNWMBL is online now
Currently: Not set.
SNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond reputeSNWMBL has a reputation beyond repute
Default
You posted in my build thread on TY. Pretty cool setup and very light. I wonder what the lifespan of that capacitor is?
  #10
Old 02-02-2017, 07:41 AM
Barcode's Avatar
Currently: Spoon!!!
  #11
Old 02-03-2017, 09:46 AM
idahosledder idahosledder is offline
Currently: Not set.
idahosledder has disabled reputation
Click Here to Register
  #12
Old 02-03-2017, 03:00 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
  #13
Old 02-03-2017, 03:39 PM
Barcode's Avatar
Currently: Spoon!!!
  #14
Old 02-06-2017, 03:30 PM
Kieselguhr Kid Kieselguhr Kid is offline
Currently: Not set.
Basic Member
Kieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond reputeKieselguhr Kid has a reputation beyond repute
  #15
Old 02-08-2017, 05:16 PM
jeffheart153 jeffheart153 is offline
Currently: Not set.
Basic Member
jeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond reputejeffheart153 has a reputation beyond repute
  #16
Old 02-13-2017, 06:55 AM
Barcode's Avatar
Currently: Spoon!!!
The Following 2 Users Say Thank You to Barcode For This Useful Post:
Snowmixer (02-13-2017), swrev (02-13-2017)
  #17
Old 02-14-2017, 08:29 AM
kuart kuart is offline
Currently: Not set.
Basic Member
kuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond repute
  #18
Old 02-15-2017, 07:31 PM
off trail mike off trail mike is offline
Currently: Have snow...have sled.!!!
off trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond reputeoff trail mike has a reputation beyond repute
  #19
Old 02-15-2017, 09:54 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
  #20
Old 02-16-2017, 07:24 AM
Barcode's Avatar
Currently: Spoon!!!
  #21
Old 02-16-2017, 07:25 AM
Barcode's Avatar
Currently: Spoon!!!
  #22
Old 02-16-2017, 05:15 PM
  #23
Old 02-16-2017, 07:47 PM
Currently: Not set.
  #24
Old 02-16-2017, 10:02 PM
Currently: Not set.
  #25
Old 02-17-2017, 07:24 AM
Barcode's Avatar
Currently: Spoon!!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Replacement Battery for my Nytro Thread Starter — turboyammy Forum — Nytros! Replies — 5 Last Post — 11-20-2015 03:17 AM
Thread — Light weight battery for XP? Thread Starter — Dave Forum — Ski-Doo: XP Sleds Replies — 30 Last Post — 11-15-2010 10:21 AM
Thread — Garmin GPS 12cx internal memory battery replacement! Thread Starter — jarspoon3 Forum — GPS enabled devices Replies — 1 Last Post — 03-12-2010 11:34 PM
Thread — RT 1000 replacement battery and low pres. pump Thread Starter — 009 Forum — Ski-Doo Replies — 3 Last Post — 02-13-2009 11:03 AM
Thread — how much weight do you save by pulling the m1000 headlights? Thread Starter — SWEETXPBEATCH Forum — Arctic Cat Replies — 19 Last Post — 11-26-2008 09:17 AM
no new posts
