Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 01-29-2017, 05:17 PM
Jeepermat Jeepermat is offline
Currently: Not set.
Basic Member
Jeepermat is an unknown quantity at this point
Default 99 670X Summit running away
I have a 670 HO that had some wiring issues when I bought it that prevented it from getting above 3000rpm, I believe it was due to the DESS.
I put a new wiring harness in, and now it runs above 3000rpm fine, however it wont come back down!
Carbs are cleaned, and are moving freely. It idles fine, but as soon as you blip the throttle the rpm's start climbing and wont stop until 8krpm.
When it does this both racks are at the idle position.
I cant find any air leaks, the boots are new. If I put my hand over the carb when it does it to choke it out the rpms will fall pretty quickly, and just come back to idle and sit there. As soon as you touch the throttle it takes off again.
Any ideas what could be causing this?
Rate this post: Yes | No
  #2
Old 01-29-2017, 08:47 PM
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
Pilot plugged or too small? Slide height is correct after the carb cleaning? Is this sled old enough to have a primer? If so, disconnect it and see if it changes how the idle goes up. It could be siphoning fuel through the primer.
Making JIS screws into junk
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 99' SUMMIT 670X not running??? HELP Thread Starter — wags19 Forum — Ski-Doo: S-2000 and older Replies — 10 Last Post — 01-03-2013 09:45 PM
Thread — What mods to make to a '97 670X running boards? Thread Starter — phazertwo Forum — Ski-Doo: S-2000 and older Replies — 6 Last Post — 11-13-2010 12:20 PM
Thread — 99 summit 670x turbo Thread Starter — outlaw11j Forum — Ski-Doo Replies — 1 Last Post — 01-03-2008 05:37 PM
no new posts
