Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 01-29-2017, 12:19 PM
CatConvert CatConvert is offline
Currently: Not set.
Basic Member
CatConvert is an unknown quantity at this point
Default 2001 800 RMK Assistance
Hoping to get some help on diagnosing a problem. Had to leave my sled in a difficult area and I am hoping to go back and fix it rather than tow it out. Sled started out the day running great as it usually does. Shortly after it started bogging badly but more like a cylinder was cutting out not like it was getting loaded up due to jetting. Occasionally while feather the throttle to get it go it would kick in for a few seconds and run like nothing was wrong. Often times when getting read to start from a stop i'd have to step off to get it moving so the problem was worse with a load on it. I'm really getting the feeling it's and electrical issue. The headlight has been unusually dim for a while and recently it brightened back up like it should be and then the day before it crapped out the light was flickering from dim to bright. The machine had persistent stator problems in the past but not for a while. Also during the ride, but noticed after the problems started, the exhaust developed a large leak, could improper back pressure cause the symptoms as well? Plugs were not great but they were not fouled out either. I changed to a new set and it ran good for about 10 seconds and the problem continued. Thanks for any help.
Rate this post: Yes | No
  #2
Old 01-29-2017, 01:13 PM
olymon's Avatar
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
Exhaust has a large leak? Do you mean there is fuel spitting out the muffler, cracked pipe, whatever. Cracked exhaust would mess up your performance big time.
Making JIS screws into junk
  #3
Old 01-29-2017, 03:10 PM
Currently: Not set.
Basic Member
Default
Yeah there is a pretty good gap where the pipe joins the header. Looks like the pipe rusted through you can see flames coming out in daylight.
  #4
Old 01-29-2017, 08:50 PM
olymon's Avatar
Default
Got to be someone with a stock exhaust sitting on a shelf in their pole barn after they piped the one they had. Post up in the WTB section.
  #5
Old 01-30-2017, 01:02 AM
Currently: Not set.
Basic Member
Default
High temp JB weld to get it out? Thoughts?
  #6
Old 01-30-2017, 12:28 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Quote:
Maybe not the best idea to use JB weld as it takes a few hours to totally harden. It could break up and get sucked back into cylinder. Is there room to make a "bandage" out of light steel and clamp it over the hole in the pipe?
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #7
Old 01-30-2017, 12:57 PM
olymon's Avatar
Default
Maybe aluminum flash like you use on a roof? Easy to form to the shape you want using heavy scissors. Hose clamps or mechanics wire it.
  #8
Old 01-08-2018, 09:23 PM
sledmasterminion sledmasterminion is offline
Currently: Hopefully sledding
sledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant futuresledmasterminion has a brilliant future
Default
I have a 2001 sitting here with a good exhaust. Boise area.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2001 RMK 800 Thread Starter — swade-o Forum — Polaris: GEN 2 Replies — 12 Last Post — 08-23-2013 03:43 PM
Thread — 2001 800 RMK Mod & 2002 550 Trail RMK Thread Starter — recreationist Forum — Polaris (Swapmeet) Replies — 0 Last Post — 12-13-2012 02:04 PM
Thread — Anyone In the bozeman/belgrade area W/ a clean pro-rmk. needing some assistance Thread Starter — Wheel House Motorsports Forum — Montana Replies — 0 Last Post — 08-18-2012 04:15 PM
Thread — Dragon 700 RMK RPM issue. Could use some Snowest assistance!!! Thread Starter — xtralettucetomatoe580 Forum — Polaris Replies — 6 Last Post — 02-22-2008 08:40 PM
no new posts
