Upgrade to Premium
Reply
  #1
Old 01-25-2017, 11:22 PM
justinwmx20406 justinwmx20406 is offline
Currently: Debating on a 18 mtn cat 🤔
Basic Member
justinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond reputejustinwmx20406 has a reputation beyond repute
Garage
Default Anyone do a 16 front end on a 12?
All the kits say 13-15 ..
Will it work for a 12?
Rate this post: Yes | No
  #2
Old 01-27-2017, 12:34 AM
catdieselpwr catdieselpwr is online now
Currently: Not set.
Basic Member
catdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond repute
Default
U need to find 16.5in center to center front shocks, the spacers in the 16 kits are for the 13-15 38 front ends. Other than that direct bolt on and it's worth it, I did my 12 and had to learn how to ride it again. Makes that 1100 feel like it lost 60 lbs lol.
  #3
Old 01-27-2017, 06:43 AM
Basic Member
Garage
Default
Yeah i have a 16 front end on my 14 m8000 it makes a huge difference .
The reason I ask is the a arm bolts and bushings are bigger on 12 and wasn't sure if tue ones in the kit fit or not ....i know about the shocks
  #4
Old 01-29-2017, 07:55 PM
Currently: Not set.
Basic Member
Default
If u buy the front end kit from cat, it comes with all the new hardware and bushings etc.
  #5
Old 01-31-2017, 08:16 PM
PISTONPETE's Avatar
PISTONPETE PISTONPETE is online now
Currently: Wrenching
PISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond reputePISTONPETE has a reputation beyond repute
Default
What exactly is the difference between them? Caster?? Are the spindles more forward from stock ??
  #6
Old 02-01-2017, 09:13 PM
blackjack85335 blackjack85335 is offline
Currently: Love my M1100
blackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond reputeblackjack85335 has a reputation beyond repute
Default 36" kit
Not sure about spindles having much difference but I'm having a 36" barcode kit installed on my M1100 next week and we're using the stock 12 spindles instead of going with 16 spindles for $400+ more. I have a 38" kit now and was told the difference between a 38 and 36 is the same as going 40 to 38. Difference between barcode and cats kit is barcode moves the spindles forward 5" compared to stock. It lengthens the overall wheelbase if you will of the sled. In turn it's suppose to make it easier to initiate a sidehill. As soon as I get my kit I'll post my findings. I'm also going with raptor shocks up front instead of stock float 2's.
The Following 3 Users Say Thank You to blackjack85335 For This Useful Post:
bigrig (02-03-2017), fishstick (02-02-2017), jeffheart153 (02-02-2017)
  #7
Old 02-02-2017, 06:18 PM
ReaperMotorsports ReaperMotorsports is offline
Currently: Modifying
ReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond reputeReaperMotorsports has a reputation beyond repute
Default
Last month I installed the 365 Barcode Front End on my 1100 with the new 16 spindles. All in all it went together pretty good. Few minor things during assembly that I tweaked to my liking and had to do some major thinking on how to mount the shock to the upper mount on the left side due to there being a turbo right there on that side compared to the 800s and vipers that dont have anything there to begin with. So after some time on the computer and some fabrication work I designed a new upper shock mount to fit in the tight area left just behind the turbo that mounts to the original shock mount and also ties into other areas of the front end so it wouldn't fold right up all while keeping it able to rotate freely throughout the stroke of the shock. After all that I was excited to try it out. On the floor it felt completely different than it did before at 38". Lays over alot easier and out riding with it was a blast. Alittle learning curve to see how it was going to react. I sure didn't have to work it nearly as hard as before and wont be going back. When I get some time I will be jigging up my upper shock mount for anyone that wants one on there 1100.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to ReaperMotorsports For This Useful Post:
bigrig (02-03-2017), blackjack85335 (09-08-2017), kuart (03-03-2017)
  #8
Old 02-02-2017, 09:24 PM
Default Shock mount
I'm interested in your left shock mount.
The Following User Says Thank You to blackjack85335 For This Useful Post:
bigrig (02-03-2017)
  #9
Old 02-03-2017, 03:47 PM
Barcode's Avatar
Barcode Barcode is offline
Currently: Spoon!!!
Barcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond reputeBarcode has a reputation beyond repute
Default
Its a super super nice piece!! Ive seen pictures.
Glad everyones enjoying the kit. Were super proud of it.
Cheers
Allan
  #10
Old 03-02-2017, 09:52 PM
Default pics soon
I have the barcode front end on my 12 M1100. I'll post pics next week with the new raptor shocks. Looking forward to my first ride with the new front end as well as my first ride of the season. Lack of snow this winter and break downs have prevented me from getting any riding in yet this season. Going to ride every chance I get until the snows gone. Going to put the front end to the test every ride. I'll report back after I get some time on it.
Barcode (03-03-2017)
  #11
Old 03-03-2017, 04:04 PM
kuart kuart is offline
Currently: Not set.
Basic Member
kuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond reputekuart has a reputation beyond repute
Click Here to Register
  #12
Old 03-03-2017, 07:26 PM
  #13
Old 03-29-2017, 07:57 PM
kcdavidak kcdavidak is offline
Currently: turbo m8
kcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond reputekcdavidak has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New BDX front end vs. 2016 Cat front end? Thread Starter — specialk6r Forum — Arctic Cat: Proclimb M Replies — 17 Last Post — 01-09-2017 01:27 PM
Thread — Will '13 Assault front end bolt up to Pro front end? Thread Starter — snowracer21 Forum — Polaris: Pro-Ride Replies — 9 Last Post — 10-16-2013 12:36 PM
Thread — Anyone wanna trade a '12 HCR front end for your 38" front end...? Thread Starter — RyanD121 Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 11-24-2012 10:44 PM
Thread — FS or Trade for 43" front end in canada (09 m8 sp front end) Thread Starter — Mod800R Forum — Suspension/Shocks (Swapmeet) Replies — 4 Last Post — 09-21-2010 11:36 AM
Thread — Oilite Front End Bushings for Barkbuster Front End Thread Starter — srxspec Forum — Yamaha Replies — 63 Last Post — 03-12-2009 04:38 PM
no new posts
