Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 01-25-2017, 06:01 PM
2XM3's Avatar
2XM3 2XM3 is online now
Currently: 2016 axys
2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute2XM3 has a reputation beyond repute
Default NEW CLUTCH THREAD
now running, 2016 slp pipe diamond s can pro quick drive gears
MTX 68 gr
120-333 primary spring
56-40 .36 helix
black purple spring + 2 delrins
pulls 8350-8400
will test more and update
__________________
2013 and 2014 National Superboat Champions
1 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to 2XM3 For This Useful Post:
diamonddave (01-25-2017), mountainhorse (02-04-2017), wellfed777 (12-15-2017)
  #2
Old 01-25-2017, 07:46 PM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
Default
That's pretty messed up that your thread has disappeared. You had dedicated alot of time and information to that thread.
The Following 2 Users Say Thank You to diamonddave For This Useful Post:
2XM3 (01-26-2017), ghost rider (12-10-2017)
  #3
Old 01-26-2017, 05:39 AM
2XM3's Avatar
Default
wish they had made it a stickey as there was a ton of good stuff in there
__________________
  #4
Old 01-26-2017, 06:53 AM
Jona$ Jona$ is online now
Currently: sks800 -16
Jona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond reputeJona$ has a reputation beyond repute
Default
Im running sealevel with clutchkit from indydan
Primary:
v5-3 weights hole1 2.5gr hole 2 2.5gr hole 3 1gr hole 4 1 gr
spring 140/330 spring
secondary:
Helix they wont say.
125/175 spring
both clutches stay cool after long pulls and no belt slippage.
but im only pulling 8100-8150rpm.
tried removing 2gr from hole 2 to witch gave me 8200rpm, removed the last 0.5gr in hole 2 and suddenly it seem to pull 8000-8100 again.. that doesnt add up. for a notice the temp outside was warm this day, 35f and i know i can loose roughly 200rpm then but the temp usually doesnt effect my sled, probably due to seelevel.
tps is set.
should i start with empty weight and see if i pass the 8400rpm and if so start adding weight from hole 1.
The Following User Says Thank You to Jona$ For This Useful Post:
Norway (03-09-2017)
  #5
Old 01-26-2017, 07:38 AM
snobyrd snobyrd is offline
Currently: in memory of Johnny,JAN 23 2011
snobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond reputesnobyrd has a reputation beyond repute
Default
I got a phone call from a dealer last week thats very tight with polaris engineering management, he was asking me why i was looking for gearing pulleys, i mentioned about inconsistent clutching, he told me the whole problem is in the fuel map and proceeded to say that pol clutching from factory is as good as ur gonna get as they don't like to leave anything on the table.but he did say the slp weights were a good weight for the axys and trying the blk purple spring was good for backshift but some dont like the revy noisy feeling, incl me.
He said 2016s are lean in mid rich on top , 2017s rich mid and lean on top.
He said he shared his dissatisfaction with pol about the mapping and advised them to get it right, so i think were all chasing our own tail untill the mapping becomes better.
Ive been around the world with clutching on this thing , spent many hundreds of dollars on clutch parts and am at the point of just running stock with empty 71 grm mtx weights clutching and im gonna try pro gearing latter this week.
You know there's a mapping problem when u can add a pipe without adding a controller.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to snobyrd For This Useful Post:
2XM3 (01-26-2017), guidoxpress (01-26-2017), pman_ (12-18-2017)
  #6
Old 01-26-2017, 08:54 AM
2XM3's Avatar
Default
Probably why they did the straight helix, I will say that it liked the 56 .36 start angle better than the 60 .46, but both pull better down low that the .40 straight, I have never ever seen a n/a sled that ran better with a straight helix so the fuel theory sounds pretty good
__________________
The Following User Says Thank You to 2XM3 For This Useful Post:
snobyrd (01-27-2017)
  #7
Old 01-26-2017, 09:45 AM
Default
Quote:
Primary:
secondary:
125/175 spring
tps is set.
I would try the stock primary spri g, i just tried that same spring and didnt like it, got simular results, its got less pounds per inch rate than stock for starters and second of all , its engagement is like 4400, stock is 3700 with 71 grm mtx weights.
  #8
Old 01-26-2017, 10:14 AM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
Quote:
MTX 68 gr
56-40 .36 helix
pulls 8350-8400
Currently I am running
SLP Pipe and Can, no resistor, Ethanol mode below 4000 ft.
EPI Belly Buster 64 gram weights
120-340 Primary
straight 40 Helix
Venom 170-240 secondary
roller needle bearing plate with 2 roller plates
2.4 gearing (2.1 /.875 for 7 tooth)
The Belly Buster weights are very aggressive and I tried a 56-40 helix and 62-42, 62-40 helixes. With low heel weight these other helixes worked better but they make it difficult to not spin the track with the Belly Busters. The straight 40 offsets this problem. Good RPM, maybe a little low over 7000 ft (8150), but really fast back-shift and recovery. So far best set up I have found.
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
The Following 3 Users Say Thank You to Teth-Air For This Useful Post:
2XM3 (01-26-2017), Norway (03-09-2017), xmk1080 (02-04-2017)
  #9
Old 01-26-2017, 11:47 AM
NoSoup4U NoSoup4U is offline
Currently: Not set.
NoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond reputeNoSoup4U has a reputation beyond repute
Default
This is what I'm running in my 174. I've found the 174x3 needs to be clutched lighter and with more backshift than a 163x2.6 does.
17 174 with Bikeman pipe, can, y-pipe and Bully Dog program.
8-10,000 elevation
SLP Magnum Force weight - no added weight
SLP blue/pink primary
Black/purple secondary with one dehlrin
Stock 40 helix
Pulls 8300-8400 all day long whether climbing, in the powder or down the trail. I like the stock primary spring better for low speed crawling, but peak RPM aren't as consistent as the SLP blue/pink.
  #10
Old 01-26-2017, 12:40 PM
AdrenalineAddict AdrenalineAddict is offline
Currently: Looking Forward To A 0Degree Afternoon!!
Basic Member
AdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond reputeAdrenalineAddict has a reputation beyond repute
Default
Have some of you seen gains at 8,300 to 8,400. I've left my sled as stock running 10-62's at +9,000', it turns 8,100 at elevation even in deep powder pulls. My friend has tried a few other recommended set-ups some spinning 8,300 r's. The day he was turning high rpm's I could outrun him by a good margin 1MPH to 2MPH in all conditions. Seems to me having a couple dozen rides under my belt that 8,100 to 8,150 is spot on.
  #11
Old 01-26-2017, 03:30 PM
Currently: Not set.
Click Here to Register
  #12
Old 01-26-2017, 03:50 PM
krillnecks krillnecks is offline
Currently: Not set.
krillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond reputekrillnecks has a reputation beyond repute
  #13
Old 01-26-2017, 11:17 PM
980K 980K is offline
Currently: Not set.
Basic Member
980K is an unknown quantity at this point
  #14
Old 01-27-2017, 07:13 AM
kylant kylant is online now
Currently: Getting ready
kylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond reputekylant has a reputation beyond repute
The Following 2 Users Say Thank You to kylant For This Useful Post:
ggcustoms (01-27-2017), Tewstroke (12-22-2017)
  #15
Old 01-27-2017, 07:51 AM
2XM3's Avatar
The Following 2 Users Say Thank You to 2XM3 For This Useful Post:
980K (01-27-2017), ggcustoms (01-27-2017)
  #16
Old 01-27-2017, 07:54 AM
2XM3's Avatar
  #17
Old 01-27-2017, 10:14 AM
alstar's Avatar
alstar alstar is offline
Currently: Waiting on Snow
alstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond reputealstar has a reputation beyond repute
The Following User Says Thank You to alstar For This Useful Post:
  #18
Old 01-27-2017, 01:57 PM
Teth-Air's Avatar
The Following User Says Thank You to Teth-Air For This Useful Post:
cmxuser (12-18-2017)
  #19
Old 02-01-2017, 01:19 PM
Teth-Air's Avatar
  #20
Old 02-04-2017, 10:53 AM
2XM3's Avatar
  #21
Old 02-04-2017, 03:57 PM
randy542 randy542 is offline
Currently: Not set.
Basic Member
randy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant futurerandy542 has a brilliant future
  #22
Old 02-04-2017, 05:43 PM
2XM3's Avatar
  #23
Old 02-06-2017, 01:27 AM
Snowbird11 Snowbird11 is offline
Currently: Mentating
Snowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond reputeSnowbird11 has a reputation beyond repute
Garage
  #24
Old 02-06-2017, 08:23 AM
  #25
2XM3's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Clutch thread gone Thread Starter — Jona$ Forum — Polaris: AXYS Replies — 10 Last Post — 01-25-2017 05:24 PM
Thread — CLUTCH THREAD SIZE 09 m8 Thread Starter — Hardass Forum — Arctic Cat: M Series Replies — 6 Last Post — 03-09-2016 05:33 PM
Thread — Yamaha Clutch Thread Links Thread Starter — KSH Forum — Clutching Replies — 0 Last Post — 09-23-2010 08:24 PM
Thread — clutch thread Thread Starter — spring snow hero Forum — Clutching Replies — 0 Last Post — 01-26-2009 12:47 PM
Thread — First 07 clutch thread, sorry everyone... Thread Starter — summitsrule Forum — Ski-Doo Replies — 38 Last Post — 12-16-2007 09:19 AM
