Upgrade to Premium
Reply
  #1
Old 01-24-2017, 03:04 PM
SKT SKT is offline
Currently: Not set.
Basic Member
SKT is an unknown quantity at this point
Default 2015 gearing question
I have a 2015 it holds a pretty steady rpm when climbing but it just doesnt seem to have much pull or torque, will adding teeth to the top gear give it a little more torque/pull when climbing?
Rate this post: Yes | No
  #2
Old 01-24-2017, 03:21 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
What track length, elevation, and clicker are you on?
  #3
Old 01-24-2017, 06:33 PM
SKT SKT is offline
Currently: Not set.
Basic Member
Default
154 track, 7000-9000ft, clicker 4
  #4
Old 01-25-2017, 10:01 AM
gatewest gatewest is offline
Currently: Saddle up, let's ride!
Basic Member
gatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond reputegatewest has a reputation beyond repute
Default rpm's and pin weight?
What RPM's are you running at 7 - 10?
How much pin weight do you have it the clutch.
12.4-12.5 grams
adjust clickers to run 8100-8200
  #5
Old 01-26-2017, 02:23 PM
sledr4life's Avatar
sledr4life sledr4life is offline
Currently: Not set.
sledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond reputesledr4life has a reputation beyond repute
Default
I thought these sleds tuned to 7900
The Following User Says Thank You to sledr4life For This Useful Post:
sledslayer (01-31-2017)
  #6
Old 01-29-2017, 01:49 PM
SKT SKT is offline
Currently: Not set.
Basic Member
Default
I'm running 7800-7900 rpm at high altitude, I have no weight in the pins, just the pins, I believe they are bout 13.6gr, but the sled just doesn't have much torque while climbing, seems like it if I had 1 or 2 more teeth on the top gear i think it would pull a little harder?
  #7
Old 04-23-2018, 09:01 AM
HOOTS HOOTS is offline
Currently: Not set.
HOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond reputeHOOTS has a reputation beyond repute
Default
How hot due your clutches get from a climb? Is sled holding rpm while climbing? If you’re wanting more torque/power, you wouldn’t be adding teeth to top gear. Less Speed more torque add teeth to bottom gear or for larger change, take away top.
__________________
here since 2/02
16 174X
13 156 SHR T3
08 XP 163
Rev Mod
Bunch of vintage ice drag sleds
SAWS
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2015 gearing Thread Starter — sldrnm Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 01-13-2017 09:14 PM
Thread — Cr500 gearing 2015 lt Thread Starter — wwillf01 Forum — Snow bikes Replies — 11 Last Post — 03-08-2016 11:39 AM
Thread — 2015 Timbersled Sprockets/Gearing Config? Thread Starter — lorengy Forum — Snow bikes Replies — 4 Last Post — 01-06-2016 01:05 PM
Thread — Gearing question Thread Starter — soft hat Forum — Ski-Doo Replies — 3 Last Post — 09-07-2010 09:43 PM
Thread — M8 gearing question Thread Starter — boosted1 Forum — Arctic Cat: M Series Replies — 1 Last Post — 07-27-2009 09:53 AM
