Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 01-23-2017, 11:55 PM
rmkrazi rmkrazi is offline
Currently: Under a dead Idaho sky
Basic Member
rmkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond reputermkrazi has a reputation beyond repute
Default Killing Belts
At the start of the season I smoked a ski-doo belt after 50 miles (had less than 700 miles on belt, not blown) Put on a cheapo belt from advanced auto and now its shredded (not blown, but ripping apart on one side.) 1000 miles ago I tried to mitigate the problem by "floating the secondary" which means I put in a piece of aluminum that basically extends the jack shaft, allowing the secondary clutch to have some axial play. I guess this didn't work, so I need a better solution. THANKS!
Rate this post: Yes | No
  #2
Old 01-24-2017, 12:39 PM
Ox's Avatar
Ox Ox is offline
Currently: Drainin' the swamp!
Ox has disabled reputation
Default
Buy a new "127" Doo belt?
In 15 years @ 2 sleds most of the time, the only 127 that I have ever shredded was when towing out a dead sled too fast.
They last nigh forever if you have your motor aligned and your bump stop is in place.
__________________
Looks like I lost my old post count ... AGAIN....
Hey - it was a good run while it lasted...
Ask me about aftermarket Doo recoils.
Life Insurance
Death Insurance
  #3
Old 01-24-2017, 01:36 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
I would start by verifying both clutches are in perfect condition as far as bushings, rollers etc...
That there is no binding or excessive resistance in the drivetrain between the secondary and the track. Bad bearing, chain too tight, track too tight?
Make sure you are seeing proper RPM at full throttle. Too much or too little RPM will raise belt temps.
Look for any way water or snow might be getting in. Just a little water or snow on the clutch can cost you a belt.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — This cr500 is killing me Thread Starter — Screedman Forum — Snow bikes Replies — 35 Last Post — 11-17-2017 01:31 PM
Thread — Killing a Toyota. Thread Starter — X2Freeride Forum — Fouled Plug Replies — 9 Last Post — 05-04-2011 05:55 PM
Thread — killing a 92 phazer Thread Starter — rusty Forum — Yamaha: 2-stroke Replies — 1 Last Post — 12-23-2009 04:56 PM
Thread — KILLING PLUGS!! Help!!! Thread Starter — BBQ_SAUCE Forum — Polaris Replies — 15 Last Post — 01-02-2009 09:10 PM
Thread — More killing... Thread Starter — 24footjet Forum — Fouled Plug Replies — 11 Last Post — 09-05-2008 09:57 AM
