Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 01-23-2017, 11:22 AM
zr600 zr600 is offline
Currently: Not set.
zr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond reputezr600 has a reputation beyond repute
Default 800 efi 1m problems?s
Ok I'm trying to get my 800 efi running it has spark good compression the fuel rail pressure is good when I primed the fuel pump with a small battery. But it won't start and the fuel pressure drops to like 20-30 when I start pulling it over and have the fuel pump plugged into he power from the sled. I also unplugged the fuel pump and put battery power to it with good fuel pressure and it still won't start. What is the issue? Any ideas would be great.
Rate this post: Yes | No
  #2
Old 01-23-2017, 11:43 AM
Sledbrain2 Sledbrain2 is online now
Currently: Not set.
Basic Member
Sledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond repute
Default
I would put a mulit meter on the fuel pump and make sure you are seeing 12 to 18 volts each time you pull the rope. I did have a tps (throttle position sensor) go bad on mine 02 800. I would pressurize the rail then apply voltage to each injector with a 9 volt batter and some alligator clips, I would hear the gas spray, it would start fine but was very erratic maintaining rpm once underway. I also had to replace the fuel pump with about 2000 miles.
Dump fuel down each cylinder and see if it will fire and run.
  #3
Old 01-24-2017, 04:55 PM
Currently: Not set.
Default
Ok I think I'm just severely flooded and that's why it won't start. Think I have a crankcase full of fuel. I have spark, compression, and fuel but it won't fire the plugs are always wet when I pull them. What works the best to clear out a severely flooded efi sled? I have blown compressed air down into the cylinders with the piston all the way down to try and clear it out. Pulled the pipe to make sure that wasnt plugged good there. There was a puddle of fuel on the ypipe. So what works to clear this out anybody have any good ideas?
  #4
Old 01-24-2017, 09:14 PM
Currently: Not set.
Basic Member
Default
I would think it is almost impossible for an efi to flood the crank case, I could be wrong.
  #5
Old 01-25-2017, 07:17 AM
Currently: Not set.
Default
Well I thought the same but it pushing fuel through to the ypipe and smells like fuel. Plugs are wet. I have fuel spark and compression so it has to be extremely flooded some how.
  #6
Old 01-25-2017, 05:00 PM
Currently: Not set.
Default
Finally got it going it runs great once I got it going.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — EFI problems!!! help Thread Starter — arcticcatwill Forum — Arctic Cat: 1M Replies — 0 Last Post — 01-03-2011 03:16 PM
Thread — PLEASE HELP 96 500 EFI engine problems Thread Starter — NOMOSNOW Forum — Polaris: GEN 1 and older Replies — 5 Last Post — 11-16-2010 12:03 AM
Thread — 800 efi crank problems, PLEASE HELP Thread Starter — arcticcatwill Forum — Arctic Cat: 1M Replies — 2 Last Post — 01-07-2010 09:38 PM
Thread — 99 ZL 600 EFI problems Thread Starter — indysledhedd Forum — Arctic Cat: Powder Special and older Replies — 4 Last Post — 01-07-2010 01:32 PM
Thread — '02 800 EFI problems w/ EFI Thread Starter — Rick Matney Forum — Arctic Cat Replies — 6 Last Post — 01-26-2008 11:37 AM
no new posts
