Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 01-20-2017, 11:01 PM
shj shj is offline
Currently: Not set.
Basic Member
shj is an unknown quantity at this point
Default Re-Engineered REV Recoil Assembly
If anyone is tired of buying 20$ recoil kits every season, because of all the problems associated with the current design. Let me know as I am currently in the process of making a new assembly that should last forever.
It would use your existing recoil housing, but the internal components would be CNC machined from aluminum and anodized for a better heat resistance and smoother sliding surface. The plastic tabs would be gone forever, and replacing them are thicker stronger aluminum locked connection....The plastic is known to slip past the tabs and become useless.....I've had to rip apart my recoil out on a ride and put it back together and it's not a fun experience.
The internal parts are known to come off their housing and rattle around and damage other parts. With this new design the snap ring is replaced with a ring type cap with a hole pre drilled so you can drill through the top plastic and use a cotter pin to seal everything.
I am currently using a bolt and a washer at the end of my recoil assembly and it seems to be working for the time being.
I need to know if there is any interest for me to show a prototype on the forums or if anyone thinks they would be intersted in seeing how it works? before you decide you want one for your sled.....This is for REV model ski doo sleds.
Mine is an 07 MXZ 591cc 121"
- race suspension rs4
- 440 gearing
- clutch kit
- V force 3 reeds
- 1.75" backcountry x track
- Freeride skis
- MBRP trail can
- WRP seat, running boards, and extra cold air intake kit installed.
- Timbersled A arms, narrow stance and skis further ahead.
- Frogskinz
- scs wrap
- 7" riser
- purple secondary spring
- ipone oil
- xtx belts
Rate this post: Yes | No
  #2
Old 01-22-2017, 01:21 AM
shj shj is offline
Currently: Not set.
Basic Member
Default Quick fix for the mean time
https://www.youtube.com/watch?v=EWZeA-fYRnw
  #3
Old 01-23-2017, 04:14 PM
shj shj is offline
Currently: Not set.
Basic Member
Default 07 Rev SideHill 121" track 591cc
https://m.youtube.com/watch?v=JLTT-y33jrQ
Click image for larger version
ID:	279567   Click image for larger version
  #4
Old 01-23-2017, 04:20 PM
whitefish's Avatar
whitefish whitefish is online now
Currently: I have reached the limit of my Free Basic Member reading privileges.
whitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond repute
Default
It's already being done.
  #5
Old 01-23-2017, 05:54 PM
shj shj is offline
Currently: Not set.
Basic Member
Default
How so? Can you elaborate on "it's already being done" ?
  #6
Old 01-23-2017, 06:19 PM
whitefish's Avatar
Default
Quote:
Sent you a message.
The Following User Says Thank You to whitefish For This Useful Post:
shj (01-23-2017)
  #7
Old 01-23-2017, 09:51 PM
shj shj is offline
Currently: Not set.
Basic Member
Default
What do you mean by it's already being done?
rev recoil
Aluminum housing;
http://www.midwestproductionmachining.com/contact.html
Aluminum Pawl:
http://m.ebay.com/itm/192073811611?_mwBanner=1
Only 2 pieces that need to be aluminum. Frankly, just the pawl needs to be aluminum if some heat shielding is applied to the recoil housing. I have studied and repaired these things for years and it comes down to really being clean and using the proper lubricant. All that is maintenance. Obviously lower to no maintenance would be great. The aluminum pawl has eliminated failures. The second it starts to drag, it gets cleaned and lubed. Just my input.
  #8
Old 02-02-2017, 02:55 PM
NEWDUCK NEWDUCK is offline
Currently: one ski dreams
Basic Member
NEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond reputeNEWDUCK has a reputation beyond repute
Default
Isnt the 1000 pawl aluminum?
  #9
Old 02-03-2017, 04:48 PM
shj shj is offline
Currently: Not set.
Basic Member
Default
Yea I've heard that there is a model with an aluminum pawl and that is possibly it yes….but I am in the process of making a complete new assembly…all aluminum and hopefully anodized….eliminating all failures…no more snap ring either…going to use cotter pin like in the power modz video….
  #10
Old 02-05-2017, 10:21 PM
Reeb's Avatar
Reeb Reeb is online now
Currently: Restoring my old race sleds....
Reeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond repute
Garage
  #11
Old 02-07-2017, 09:23 AM
Basic Member
Click Here to Register
  #12
Old 02-07-2017, 12:36 PM
shj shj is offline
Currently: Not set.
Basic Member
  #13
Old 02-09-2017, 09:22 PM
wwracer's Avatar
wwracer wwracer is online now
Currently: Riding till it's all gone
wwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond reputewwracer has a reputation beyond repute
The Following User Says Thank You to wwracer For This Useful Post:
Reeb (02-10-2017)
  #14
Old 02-10-2017, 10:45 PM
shj shj is offline
Currently: Not set.
Basic Member
  #15
Old 03-06-2017, 09:56 PM
shj shj is offline
Currently: Not set.
Basic Member
  #16
Old 03-07-2017, 04:09 PM
shj shj is offline
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — M7 recoil assembly Thread Starter — RACINSTATION Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 12-22-2011 10:13 PM
Thread — Recoil assembly Thread Starter — Tuesday Forum — Ski-Doo: REV Sleds Replies — 0 Last Post — 02-07-2011 11:35 PM
Thread — recoil dis-assembly on IQ Thread Starter — mtn mike on boost Forum — Polaris: IQ Replies — 1 Last Post — 10-26-2010 07:28 PM
Thread — Recoil Assembly Needed for 05 Rev 800 Thread Starter — darens Forum — Ski-Doo (Swapmeet) Replies — 0 Last Post — 01-08-2009 09:20 AM
Thread — Recoil Assembly Needed for 05 Rev 800 Thread Starter — darens Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 01-08-2009 09:18 AM
no new posts
