Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 01-19-2017, 11:33 AM
Merlin's Avatar
Merlin Merlin is offline
Currently: Where's the snow?
Merlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond reputeMerlin has a reputation beyond repute
Default Mikuni VM Slide Spring Tension
Good morning!
I'd like to reduce the amount of tension on the throttle slide springs(VM30) on our Indy lite to make it easier for our son's thumb.
What are your thoughts on trimming the springs VS installing lighter springs? - How much can you trim before there are legitimate concerns of the slides sticking from ice? What P/N to use if a lighter spring is the way to go?
FYI, the cables are all moving freely & have been lubed. The springs are just too stiff! LOL
TIA
Glen
Rate this post: Yes | No
  #2
Old 01-19-2017, 11:49 AM
olymon's Avatar
olymon olymon is offline
Currently: project parts searching
olymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond reputeolymon has a reputation beyond repute
Default
You could probably cut 1/4 of it off and be fine, maybe more. Curl the cut off end in a little bit so you know it won't to any binding.
Making JIS screws into junk
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to olymon For This Useful Post:
Merlin (01-19-2017)
  #3
Old 01-19-2017, 03:21 PM
retiredpop retiredpop is online now
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
I believe the Indy Lites used the same throttle safety switches in the throttle block as the rest of the Polaris sleds so in the event you did get a slide sticking it should shut down anyway. You should be safe to trim 1/4 to 1/3 of it away but you may have to stretch it back to the original length. There is something called "throttle gizmo" which helps for part throttle operation for smaller/weaker hands. My son has one on a Skidoo so his young girls can drive it. It works well.
http://www.clydecanride.com/
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
The Following User Says Thank You to retiredpop For This Useful Post:
Merlin (01-19-2017)
  #4
Old 01-19-2017, 08:42 PM
Merlin's Avatar
Default
Thanks guys.
Free length of the factory springs was 4.250" so I trimmed them down to 3.5". I'm pretty sure I could trim more but I'll see how the rider makes out with it the way that it is & then go from there.
Pop, you are right. The machine has a TSS & it also has a tether so we should be covered in the event of a stuck slide.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 6 mikuni round slide carbs $50 Thread Starter — CATSLEDMAN1 Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 09-10-2015 05:03 PM
Thread — Setting Up Round Slide Mikuni's On a 91 Phazer? Thread Starter — BurkeMtn Forum — Yamaha Replies — 1 Last Post — 01-30-2010 10:00 AM
Thread — 34mm Mikuni Flat slide carbs Thread Starter — westman995 Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 1 Last Post — 01-18-2010 07:45 PM
Thread — mikuni round slide Thread Starter — stock suks Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 02-03-2009 05:45 PM
Thread — Looking for mikuni carb slide(s) Thread Starter — 1FASTXC Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 10-26-2008 01:33 PM
no new posts
