Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 01-18-2017, 10:17 PM
switchbackdragon switchbackdragon is offline
Currently: Not set.
Basic Member
switchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to beholdswitchbackdragon is a splendid one to behold
Default ECU & Chassis Relay ?
I have run into a problem with my 05 rmk900 this season. This is the first year that my 900 has sat outside all summer long so when it wasn't running right. It started out with low charge indicator then moved into a start for a few seconds and die with now head light or dash operation.
After hours of research on this forum, I thank all of you for your dedication to the 900, I decided to check the stator and did find a rub through wire and loose inner liner. repaired that still the same. Then i went trough all the connections which alot of them were corroded. So cleaned and dielectric greased them. Now It will start and run but no headlight or dash. through wire testing found tha the ECU is not grounding the chassis relay. Checked all the grounds to the computer and the white with blue wire to the relay and all ohm out perfect.
My question is has any one run into this before and should I replace ECU or just put a toggle switch to ground for the relay?
Sorry so long, Thank You Jason
Rate this post: Yes | No
  #2
Old 01-19-2017, 07:07 PM
Currently: Not set.
Basic Member
Default
Has anyone else had this problem? Any other suggestions as to what else I might be missing or need to check. I did also replace the capacitor and when I ground the relay it does show almost full battery gauge.
  #3
Old 01-27-2017, 01:47 AM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Tearing up Alaskas BOMB POW
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
Default
If u can run the ecu switch go for it until u can get a good ecu. They come up on eBay pretty cheap
__________________
"Too much, is not enough"
3 2016 Polaris AXYS.
06 RMK 900
His and Hers 16 badass AXYS builds
  #4
Old 02-04-2017, 02:14 PM
Currently: Not set.
Basic Member
Default
Just an update. ran a switch to ground for relay, bypassed computer. sled ran great for about 70 miles then just quit and wouldn't restart. Tested the stator and found the yellow wires have 0 resistance. will replace stator and recheck to see if ground from computer comes back.
  #5
Old 12-11-2017, 07:27 PM
Currently: Not set.
Basic Member
Default
so over the course of the year i have found that the computer and coil wire harness at the computer have had some burn marks on them. I have replace computer once with a used one that would not supply spark. which the original one never had that problem. so I got another computer and wire harness and now the sled runs but after a short time the dash and lights go dead and the fuel pump quits. Seems like a never ending battle. Now to test the stator and voltage regulator. Maybe just replace both and pray.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — ECU relay location - gauge dead Thread Starter — procomp Forum — Polaris: Pro-Ride Replies — 3 Last Post — 02-23-2015 08:18 PM
Thread — Chassis Power Relay Part Number Thread Starter — SixtySevenGT Forum — Polaris: 900 Replies — 2 Last Post — 12-06-2013 02:42 PM
Thread — chassis relay Thread Starter — revenge Forum — Polaris: 900 Replies — 4 Last Post — 11-23-2013 02:20 PM
Thread — Chassis Relay Pic? Thread Starter — manlye Forum — Polaris: IQ Replies — 0 Last Post — 03-05-2012 02:57 PM
Thread — chassis relay Thread Starter — jlloyd Forum — Polaris: 900 Replies — 11 Last Post — 02-29-2012 01:58 AM
