Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 01-17-2017, 05:32 PM
lshobie lshobie is offline
Currently: Not set.
lshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond reputelshobie has a reputation beyond repute
Default AXYS 800 fault codes, not turbo related but always looking for input.
I have done some work to my 800 Boondocker turbo'd axys and it's been throwing some codes so i took it to the dealer to Blacks Corners Motorsport in Carleton Place Ontario. I dont have the ability to check the codes - with fix and learn the Exhaust Valves etc so a trip to them was necessary.
Codes thrown:
P1401 Exhaust Valve Actuator Diagnostic voltage low
P1407 EV actuator Position voltage low
P1410 EV actuator learning default position
We relearned the Exhaust valves, I had the cylinder out to install new rktek pistons so I may have thrown off the EV setting. Not sure why there is a low voltage code -checked the wiring and noticed some corrosion on 2 relays (in picture).
I checked the wiring to see if i could find any chaffing and I couldnt but i did tie wrap up the wiring better and fixed the position of the relays so water wont get in.
P 1546 Exhaust temp sensor unrealistic transition (no idea what this was)
P250f engine oil low (was on it's side)
P1552 Throttle stuck error (simple adjustment)
The codes below could be caused by the sled running very hot, it was up around 160 and it didnt like it. The thermostat fell apart (the little clip retaining the lower washer fell off and the spring and washer were loose)when i took it out so i removed it - still ran hot, in reinstalled it with the loose washer and spring but still running hot - my new thermostat arrives tomorrow.
P1336 Max det mag
P1337 Max det PTO
P1517 Exhaust over temp
P0217 Engine over temp fault
I had been getting det codes before i installed the turbo, then got them the odd time, ran boostane and/or avgas and didnt have an issue until the end of the season when it ran hot on the last day - maybe the thermostat packed it in then.
It is a boondocker sidekick with tial, just waiting on the Sidekick X upgrade kit from boondocker with controllable box.
Any insight would be appreciated.
Click image for larger version
ID:	279184   Click image for larger version
ID:	279185   Click image for larger version
ID:	279187   Click image for larger version
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #2
Old 01-17-2017, 05:38 PM
RDS88 RDS88 is offline
Currently: Not set.
RDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond reputeRDS88 has a reputation beyond repute
Default
Gotta love polaris
  #3
Old 01-17-2017, 05:54 PM
polarisblue polarisblue is offline
Currently: Not set.
polarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond reputepolarisblue has a reputation beyond repute
Smile Axys fault codes
I watch your clips on youtube and I have to tell you im a big fan. I live in northern NY I have the same sled you have with a sidekick and have had no issues to this point and I also have the switch to add more boost and it still works great at sea level. I would check ALL of your connections to make sure there is no moisture in them, especially the codes for low voltage makes me think its a bad connection.
  #4
Old 01-17-2017, 06:04 PM
Currently: Not set.
Default
Quote:
Hey thanks for watching! I'm hoping the dirty relays were the issue, I've taken a good look and dont see anything else jumping out at me. The codes weren't holding when on the diagnostic computer so that was a good thing I guess. I love the heck out of this and with the couple extra pounds it's going to be pretty freaky.
Cheers
  #5
Old 01-22-2017, 07:42 PM
IQR800 IQR800 is offline
Currently: Rider
IQR800 is an unknown quantity at this point
Default
Did you ever get the exhaust valve issues corrected? I'm having the same issues! Been into the dealer 3 times with no apparent fix. We have done all the obvious things i.e. the relay switches, power converter, relearn EV. All the electrical connections have been removed, cleaned, greased, and reinstalled twice now. Getting real fed up at this point, so any info is appreciated. I'll report back if I get it figured out
  #6
Old 01-24-2017, 11:14 AM
doudea's Avatar
doudea doudea is offline
Currently: waiting.......
doudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond repute
Default
A friend had the almost the same symptoms, with DET codes and various low voltage codes related to the exhaust valves. It developed into a miss on one cylinder and had a injector open circuit code. Checked ohm values on both injectors and read fine, ohmed both circuits to ground and no reference to ground. Suspected maybe pinched wiring harness, friend tore it apart and never found any suspect looking wires or connections. Tried an identical known to be good ECU, changed all capacitors, relays, voltage regulator, exhaust valve control module, and no improvement.
Finally the friend doing the work said screw it and changed out the wiring harness from his personal known to be good sled. That is what ended up fixing it. Stinking wiring harness. From what he said changing out the wiring harness wasn't that time consuming or hard. He had proved out everything except the wiring harness and that was the last ditch thing to try.
Thought I would share, because from what I remember it had very similar fault codes also using digital wrench to trouble shoot and similar symptoms.
Its not fun trouble shooting electrical gremlins. Best of luck!
The Following User Says Thank You to doudea For This Useful Post:
ROCKNESTER (03-20-2018)
  #7
Old 03-20-2018, 05:19 PM
ROCKNESTER's Avatar
ROCKNESTER ROCKNESTER is offline
Currently: Not set.
ROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond reputeROCKNESTER has a reputation beyond repute
Default
trying to help a friend diagnose some similar issues - which wiring harness did you end up replacing?
thanks,
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — What fault codes are these? Thread Starter — Cutterx Forum — Polaris: TURBO Replies — 2 Last Post — 03-05-2014 06:47 PM
Thread — Anyone have the Fault Codes for E-Tec? Thread Starter — Cutterx Forum — Ski-Doo: XM Sleds Replies — 7 Last Post — 01-10-2013 11:41 AM
Thread — Fault Codes 2011 800 etec Thread Starter — Squawnk Forum — Ski-Doo: XP Sleds Replies — 2 Last Post — 01-02-2013 09:30 AM
Thread — Fault codes? 10-9 Thread Starter — FNG Forum — Ski-Doo: REV Sleds Replies — 3 Last Post — 01-11-2010 02:26 PM
Thread — Need help with nytro fault codes Thread Starter — irondave86 Forum — Nytros! Replies — 2 Last Post — 11-23-2009 02:27 PM
