Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Closed Thread
  #1
Old 01-14-2017, 08:07 PM
lancelarue lancelarue is offline
Currently: waiting for snow!!
lancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond reputelancelarue has a reputation beyond repute
Smile 880R
Getting closer !
Received some different needles to try in the Lectrons. Testing when it quits raining!!!
Downloaded a few pics.
Click image for larger version
ID:	278989   Click image for larger version
Name:	Jaws big bore twins.jpg
ID:	278990   Click image for larger version
Name:	Mag side pipes-can .jpg
ID:	278992   Click image for larger version
ID:	278993   Click image for larger version
Name:	pipe pressure guage.jpg
Name:	Primer valve 2.jpg
ID:	278995   Click image for larger version
Name:	pto side view .jpg
ID:	278996   Click image for larger version
__________________
Old faithful :06' Summit X W/163" flex,2 wheels in rear, big drop & roll. 860R, 05' electronics, 46 mm Lectrons, custom airbox, lots of air, SLP single, Paragon, Mtn Tamer rear w/ floats all the away around,extra cooling tubes in tunnel, premix, 5 gal race tank, >
Trail sled: 07' 151" stock except 860 & paragon, other stuff
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #2
Old 01-14-2017, 09:38 PM
TreeThrasher TreeThrasher is offline
Currently: Not set.
Basic Member
TreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond repute
Default
Looks like fun! What solution did you use for the 880 and the head o rings? Weld the groove and o ring the head? Or?
  #3
Old 01-15-2017, 01:09 PM
Default 880
I did what Big John is doing & working fine so far. I'll let him tell you as it's his idea / process on the cylinder o'rings that I copied. This is my first 880 build.
On the 860 never changed anything on series 3 or the R motor. No problems but then I don't have a problem with detonation with my head designs either.
__________________
  #4
Old 01-15-2017, 01:54 PM
pfi572's Avatar
pfi572 pfi572 is offline
Currently: 2012 800 etec +++
pfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond reputepfi572 has a reputation beyond repute
Default
Your not finding that green secondary spring to much?
Running light pin weight and spring in primary?
__________________
2012 Black X 800 e tec ,174x2.5"x16"
2010 Max LTD
  #5
Old 01-15-2017, 07:52 PM
Default clutching
Well we're still figuring things out and new engine build etc.
I started out with the same clutching I've been running for several years so as to have a baseline to compare to but in the meantime I went to a different track and belt drive and geared up to 2.3 . That seems to have tipped the apple cart over! Used to be at 2.47.
My best set up has been 72 grms.+- running Thunder arms. That equates to somewhere between 19.7 and 21 grms in the pins alone, stock rollers, 433 ramps laid down .060" with a 100X260 spring up to 6,000 feet which is about it for up here in Valdez. This is at 8,250 rpm+-.
I run very little twist in the Paragon with the AC snow pro spring, maybe 1/8" to 1/4" max. Being at 55* finish that's all I've needed. Lately been running 60*X55* helix. Been running 58*X55* for several years but didn't have another helix like that for this sled so went with what I had. Can't notice any difference as far as the helix goes. Ran straight 58* in Summits for years but as I made more power couldn't hang on to the belt and so ended up at 55*. Any less than 58* start and big bores are too "buzzy".
We'll see>>>>>
__________________
  #6
Old 01-15-2017, 08:46 PM
pfi572's Avatar
Default
880 I had I ran 100/230
11 grams and a 415-441 blended ramp. 415 only for the first portion .
63/55 helix with cat yellow when I was using the older Paragon.
The newer ones with reverse cut into towers only need compression springs.
2:52 ration with belt drive and 174 track
__________________
2010 Max LTD
  #7
Old 01-16-2017, 03:22 PM
Default clutching
Interesting. That would be a really nice set up when it matched conditions.
Can't run that low of gearing as I would be wayyy up in overdrive. I'm at 2.3 and it's border line too low. Shame because I love low gearing, but I don't like to get in overdrive in the steep pulls.
I've been going to try less helix angle with a wimpy spring to try and drop some weight in the drive. Haven't got to it yet.
You can still run torsion spring with reverse cut towers. That's what I run in my trail sled. I don't like the compression spring set up. Ran it, no comparison.
TRA stalls the shift when you get to a point in top end with 441 and similar ramps. Arm loses leverage when it climbs too high. Ran 2 mm oversize rollers for years that worked but couldn't keep bushings in them. 417 ramp finished same place as 415 with 2 mm over rollers. Ground the bottom end too try & load big bores. Gave up!!!
433 ramp dropped .060" is approx same as 417 finish only with nice low engagement and HUGE bottom-mid up shift. Great big bore ramp and actually have run 433 in several little race sleds 440's and 600 mods. Just alter them to fit power curve & hold on! These were all with Paragons.
__________________
  #8
Old 01-31-2017, 07:38 PM
Default Reeds / Lectrons
Getting quite the education here.
For what it's worth, anyone wanting to try big Lectrons on Skidoo, the Boyeson 600 SDI reeds for rev chassis are a really good match.
They flow the same as 46 Lectrons and after experimenting with different petals am back to the ones that came with!!!! Was running stiffer petals in the Boyesons' but it flat didn't like it. I was all over the place with the fueling trying to make it happy, no go. Put the stock petals back in = oh yea!!!!!!!!!!!
We're making headway, had to modify airbox again, but it was worth it because it flat out is moving some air now! Had to change pipe restrictors / adjust to get pipe pressure back down.
(have some needles for sale in the swap meet)
Supposed to be nice tomorrow, we'll see!
__________________
  #9
Old 02-03-2017, 08:44 AM
Default Belt drive
Things really coming together now. Pipes are dialed in & fueling getting close enough to finish breaking in. Motor is starting to really wake up. I went ahead and pulled a degree of timing back out of it and is probably where I'll run it now. I don't think I was getting enough heat in these big twins. Made one last test pull here at home and then was heading up the mountain, I thought!
Then it started going through the belts in the belt drive. Went through the whole chassis measuring / checking. Everything is dead nuts straight. As much as I hate to do it, putting the chain case back on. I'm not going to do the extra 2 or 3 belts in the back pack thing. I know I can get by running a chain, so I'm going back to what I know works. I suspect I'm getting too much flex / things moving around to run the C3 on a Rev? Dang>>>>>>
__________________
  #10
Old 02-03-2017, 11:37 AM
  #11
Old 02-05-2017, 11:16 PM
Reeb's Avatar
Reeb Reeb is online now
Currently: Restoring my old race sleds....
Reeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond reputeReeb has a reputation beyond repute
Garage
Click Here to Register
  #12
Old 02-06-2017, 01:11 PM
The Following User Says Thank You to lancelarue For This Useful Post:
Reeb (02-06-2017)
  #13
Old 02-25-2017, 10:34 PM
  #14
Old 02-26-2017, 10:40 AM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
  #15
Old 02-26-2017, 10:42 AM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
  #16
Old 02-26-2017, 12:12 PM
  #17
Old 03-05-2017, 07:06 PM
Closed Thread
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Need new Bikeman 880R pistons ASAP Thread Starter — Hemi-Dart Forum — WTB (Swapmeet) Replies — 0 Last Post — 02-11-2013 11:57 PM
Thread — 880r bigbore Thread Starter — 07xrs Forum — Engine/Engine Parts (Swapmeet) Replies — 4 Last Post — 03-10-2012 09:10 PM
Thread — Complete BMP 880R kit ski doo Thread Starter — wazzusummit Forum — Engine/Engine Parts (Swapmeet) Replies — 5 Last Post — 12-25-2009 07:52 PM
Thread — 880R Topend & Twin Cranks Thread Starter — HPJUNKIE Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 04-12-2009 12:42 PM
no new posts
