Upgrade to Premium
Reply
  #1
Old 01-13-2017, 07:22 PM
RotaxKongen RotaxKongen is offline
Currently: Not set.
Basic Member
RotaxKongen is an unknown quantity at this point
Default IQ600R VS 600R Wiring Harnes
Hello! I need everything electric for my 800R mod (600r crankcase witb 800 cylinder) and im only finding complete harness from rr, can i use it?
Edit: IQR bottom is 2013 and RR harness 2008
Rate this post: Yes | No
  #2
Old 01-13-2017, 10:32 PM
H2O H2O is offline
Currently: Not set.
Basic Member
H2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond reputeH2O has a reputation beyond repute
Default No
The CDI for the R is completely different than the CDI for the RR. The RR was a std 600 HO motor. The 600R motor is a totally different animal with a different timing curve.
  #3
Old 01-14-2017, 06:03 AM
Currently: Not set.
Basic Member
Default
Quote:
So it is not possible to just get a iqr cdi and put on it?
  #4
Old 01-14-2017, 12:00 PM
H2O H2O is offline
Currently: Not set.
Basic Member
Default
I believe you need the wiring harness for the R. The R uses a different flywheel than the RR. The R has no provision for Perc Reverse (flywheel, CDI, etc.). There are other differences. The RR was a standard 600 HO motor with all of the regular nannies not used on the Race motor (R). Try hardcoresledder.com for more info.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — IM 900 ecu and wire harnes Thread Starter — Thunder101 Forum — WTB (Swapmeet) Replies — 1 Last Post — 11-26-2011 01:28 PM
Thread — 09 wiring harnes Thread Starter — waitemr4 Forum — Arctic Cat: M Series Replies — 3 Last Post — 01-03-2011 08:58 PM
Thread — EGT Guage wire harnes Thread Starter — mtncat800 Forum — Arctic Cat: TURBO Replies — 2 Last Post — 12-28-2010 08:06 PM
Thread — Changing to a 01 wiring harnes, to a 03 harnes??? Thread Starter — jbsumbc Forum — Ski-Doo: ZX Sleds Replies — 5 Last Post — 10-06-2009 04:15 AM
Thread — 01 zx summit Wiring harnes, and change to a 03 zx harnes???? Thread Starter — jbsumbc Forum — Performance/Modified Replies — 0 Last Post — 10-03-2009 10:27 PM
