Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 01-12-2017, 08:31 PM
Spiderman Spiderman is offline
Currently: Not set.
Spiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond repute
Default Need clutching help....Silber Pro rmk spiking rpm at throttle stab
It causes it to hit the limiter and cut out just on the on off stab of the throttle. If I am slower with the stab, its fine. 2014 pro rmk 163 with silber external, stock gearing, 7lb spring 9-10000 foot elevation, 91 pump with a splash of av. I have 72 gram rooster weights with the weight spread 5grams in the heal 2 in the middle 42-46 helix, pink primary spring and black green secondary spring that came with the kit Runs great otherwise with the latest flash. I cant add an more weight to the heal without going to the those heavy 3.5g washers Corey had me check my belt which is good. Running 8200 rpm. Clutches dont have any noticable belt marks on them. Was thinking of trying the black purple secondary spring or a steeper intial helix angle. Anybody have any other ideas to try?
Rate this post: Yes | No
  #2
Old 01-12-2017, 11:02 PM
ripnit ripnit is online now
Currently: working my a$$ off to take time off this winter to RIDE
ripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond reputeripnit has a reputation beyond repute
Default
Just a thought but a belt can get "glazed" and look fine but may slip in the primary. Also check primary spring is not broken (have seen the first coil of the spring brake and make clutch act weird.)
__________________
18 Axys 800, 163, Stock.
16 Axys 800 Snowcheck, Boondocker turbo, kmod, 280 3.5 pitch 163 track.
12 Pro Rmk 800, Boondocker Turbo, 14 motor, 163 Axys 2.6 track.
04 827 RK Tek summit X 144, DJ clutch kit, cc y and pipe, super q can, BR TECH Thrasher side pannels and hood, USI Project X skis, 06 X seat.
  #3
Old 01-12-2017, 11:10 PM
Currently: Not set.
Default
Yeah I checked that... Has done it from the start and switched to a new broke in belt and had the same thing. Sheave to belt clearance is good too.
  #4
Old 01-12-2017, 11:38 PM
wellfed777 wellfed777 is offline
Currently: Not set.
wellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond reputewellfed777 has a reputation beyond repute
Default
so you can be riding along and full throttle and it over revs ?
or from a dead stop ? or both?
  #5
Old 01-13-2017, 12:54 AM
Currently: Not set.
Default
From both a dead stop and if going along playing in the trees... hard off and on throttle hits. It misses and pops. Nothing at full throtte and nothing after the initial stab of the throttle after letting off. Ive recorded it over revving... so the belt has to be slipping or the motor isnt being loaded enough at those times?
  #6
Old 01-13-2017, 07:49 AM
LongHorn XC LongHorn XC is offline
Currently: Packing up to head to IP,Epic snow playland
LongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond repute
Default
Quote:
When you say a splash of AV fuel, how much is that?
  #7
Old 01-13-2017, 09:25 AM
Currently: Not set.
Default
3 gal per tank
  #8
Old 01-13-2017, 09:44 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
Need to move more weight out on the tip.
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #9
Old 01-13-2017, 11:03 AM
Currently: Not set.
Default
Even if I'm not hitting the limiter holding it at full throttle? I was hitting a max of 8200 at full throttle like 8150 running full throttle. Forgot to mention, it did the same thing with 3.5 grams in every hole to make it 75.5 grams at 9-10000 feet but my rpms were too low with that much weight. Still acted the same on the throttle stab.
  #10
Old 01-13-2017, 11:21 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
  #11
Old 01-13-2017, 11:33 AM
Currently: Not set.
Click Here to Register
  #12
Old 01-13-2017, 11:51 AM
Currently: Not set.
  #13
Old 01-13-2017, 12:10 PM
Currently: Not set.
  #14
Old 01-13-2017, 12:17 PM
  #15
Old 01-13-2017, 12:20 PM
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
  #16
Old 01-13-2017, 12:23 PM
  #17
Old 01-13-2017, 01:23 PM
hontri hontri is offline
Currently: enjoying my silber turbo
hontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond reputehontri has a reputation beyond repute
The Following 3 Users Say Thank You to hontri For This Useful Post:
keithw (01-13-2017), sledhead9825 (01-13-2017), wellfed777 (01-13-2017)
  #18
Old 01-13-2017, 01:45 PM
Currently: Not set.
  #19
Old 01-13-2017, 02:22 PM
  #20
Old 01-13-2017, 05:37 PM
Currently: Not set.
  #21
Old 01-14-2017, 07:02 PM
Currently: Not set.
  #22
Old 01-14-2017, 07:55 PM
Currently: Not set.
  #23
Old 01-15-2017, 10:47 AM
Currently: Not set.
  #24
Old 01-15-2017, 11:47 AM
diamonddave's Avatar
diamonddave diamonddave is online now
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
  #25
Old 01-15-2017, 12:36 PM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Pro rmk 2016 throttle rpm problems help! Thread Starter — lucasdegerman Forum — Polaris: AXYS Replies — 53 Last Post — 01-02-2018 10:31 PM
Thread — rmk 700 2002 not giving full rpm on full throttle Thread Starter — Troll-Tor Forum — Polaris Replies — 1 Last Post — 03-09-2015 08:50 AM
Thread — Best Pro Rmk Anti Stab Kit? Thread Starter — bfenrich Forum — Polaris: Pro-Ride Replies — 4 Last Post — 11-23-2014 03:20 PM
Thread — 13 pro rmk boost- it silber Thread Starter — noxis Forum — Polaris (Swapmeet) Replies — 4 Last Post — 01-26-2013 11:28 AM
Thread — 12-13 silber kit pro rmk Thread Starter — noxis Forum — Polaris: TURBO Replies — 5 Last Post — 09-21-2012 01:01 PM
no new posts
