Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 01-11-2017, 07:55 PM
blizzardking blizzardking is offline
Currently: Not set.
Basic Member
blizzardking is an unknown quantity at this point
Default Phazer ** Need help with issue
I have a 93 Phazer that was running great and then all the sudden started running bad. I put new plugs because it ran like I fouled a plug.
Tonight while the sled was running I pulled the right side spark plug connector off - the sled died.
I then put the spark plug connector back on and started the sled and pulled the left spark plug connector off while the sled was running - the sled stayed running.
Bad plug wire or something else? Any thoughts would help..
Thanks in advance for the help!
Rate this post: Yes | No
  #2
Old 01-11-2017, 08:26 PM
xr650r xr650r is offline
Currently: Not set.
xr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond reputexr650r has a reputation beyond repute
Default phazer
The best Yamaha mechanic I know that can help you works at Birds of Prey in Caldwell , Id
Dont know phone number but you can look up, his name is Rick Hill. Larry
The Following User Says Thank You to xr650r For This Useful Post:
blizzardking (01-11-2017)
  #3
Old 01-12-2017, 02:12 AM
stingray719 stingray719 is offline
Currently: 2014 Viper MTX conversion
stingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond repute
Default
Near impossible to diagnose with so little info, but a blown crankshaft seal can do that and I have seen that more than once on a Phazer. But first*do a compression test.
  #4
Old 01-12-2017, 07:11 PM
Currently: Not set.
Basic Member
Default update
Details about what has gone on with this Phazer and what I have done to diagnose the problem.
The sled was running great for several weeks and then one day while I was riding it - the sled started running like it was running on one cylinder. I checked the spark plugs and decided to change them because it ran like I fouled a plug. This has happened many of times on other Phazers we owned (and changing the plugs fixed the issue) .
After reading other posts and the recommended next steps I have done a compression check on both cylinders. Each cylinder is showing at 92.
Any thoughts on what is next?
  #5
Old 01-12-2017, 07:30 PM
LoneViper LoneViper is offline
Currently: Not set.
LoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond repute
Default
Maybe change the plug cap, go with the NGK though. Might work your way back to the coil.
  #6
Old 01-12-2017, 08:54 PM
Currently: Not set.
Basic Member
Default Found the problem
So I started tinkering with the throttle cable and found this to be the issue. Can't believe this was causing the problem.
After moving the throttle cable while it was running the sled died. I then took the plastic off and moved the cable around and found this was the source of the problem.
I appreciate all the updates and help provided! You all rock! Hope this helps someone else when they start working on an old Phazer for the kids. Needless to say my wife and kids will be happy to have this sled fixed so they can continue riding!
All the best to ya,
Blizzardking
  #7
Old 01-13-2017, 04:24 PM
Aerosled Aerosled is online now
Currently: Not set.
Basic Member
Aerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond reputeAerosled has a reputation beyond repute
Default
That sounds like the TORS (Throttle Overide System). The connections on the wires you'll find on the carburetor at the throttle linkage can be jumped to make it run in an emergency. The purpose of the TORS is to kill the engine if the throttle sticks open.
Also get a new engine to frame ground strap and make sure the connections on it are good and clean and tight.
  #8
Old 01-13-2017, 04:32 PM
whitefish's Avatar
whitefish whitefish is online now
Currently: I have reached the limit of my Free Basic Member reading privileges.
whitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond reputewhitefish has a reputation beyond repute
Default
Every issue I have ever had with a phazer has to do with the carbs. Remove, dissemble, clean, inspect repair and install.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — S/C Phazer Oil Issue Thread Starter — jwright Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 2 Last Post — 01-31-2014 09:22 AM
Thread — Supercharged Phazer odd boost issue Thread Starter — stingray719 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 17 Last Post — 12-26-2013 11:33 AM
Thread — ecu issue on phazer 07 Thread Starter — marcel Forum — Phazers! Replies — 6 Last Post — 02-08-2011 11:12 PM
Thread — 07 phazer mtn lite idle issue after ECU update.... Thread Starter — bdubs Forum — Phazers! Replies — 5 Last Post — 01-12-2011 04:43 PM
Thread — 07 Phazer starter issue Thread Starter — RX1MountainMan Forum — Phazers! Replies — 4 Last Post — 01-10-2008 04:28 PM
no new posts
