Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 01-06-2017, 10:43 PM
K3 K3 is offline
Currently: Dreaming of hunting
K3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond reputeK3 has a reputation beyond repute
Default phazer carb swap ???'s
Info on flat slide swap and which jet spec for piped reed and small bored 96 mt, lite fazer ????? Or just stay w/stock carbs re-jet from 37,5 jets to @ 160ish jets ??? Thanx l<>l !!!! (Kory)
Rate this post: Yes | No
  #2
Old 02-09-2017, 11:00 PM
K3 K3 is offline
Default
So nobody has exper. technology on this issue????? l<>l !!!!
  #3
Old 02-11-2017, 07:58 AM
gonehuntnpowder gonehuntnpowder is online now
Currently: Not set.
gonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond repute
Default
Years ago (lots of then) I ran an Aaen ported and piped Phazer. Maybe flat slides would have helped, but it sure ran good.
The Following User Says Thank You to gonehuntnpowder For This Useful Post:
K3 (02-12-2017)
  #4
Old 02-12-2017, 10:35 PM
K3 K3 is offline
Default
Thanks, have 3 w/DG and 2 w/ Aaen and 1 more super -mod that I am doing . Just checking for reality info of any experiences. Thanks l<>l !!!! Might just drill out air ports and up MJ @ 143.8 or 145's or bigger ??????
  #5
Old 05-18-2017, 01:39 PM
billybaru13 billybaru13 is offline
Currently: Not set.
Basic Member
billybaru13 is an unknown quantity at this point
Default
Im at sea level with Aaen pipe. Stock carbs 148.8M and 110P. IT will run WFO for days on this setup. The butterfly carbs throttle response is lacking a bit.. which flat slides would help out with
The Following User Says Thank You to billybaru13 For This Useful Post:
K3 (01-28-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — phazer motor swap Thread Starter — phazer25 Forum — Yamaha: 2-stroke Replies — 5 Last Post — 11-17-2014 11:33 PM
Thread — 99 700 rmk carb swap from 2000 800 Thread Starter — tubblemaker Forum — Polaris: GEN 2 Replies — 3 Last Post — 03-19-2011 10:18 AM
Thread — Need 2 know old phazer carb fix when piping Thread Starter — BIGDADDY Forum — Yamaha: 2-stroke Replies — 7 Last Post — 12-08-2009 09:37 PM
Thread — base carb setting for 93 phazer. Thread Starter — snowman Forum — Yamaha Replies — 1 Last Post — 01-05-2009 07:16 PM
Thread — Twin Carb Swap 440ss yamaha Thread Starter — madman Forum — Vintage Replies — 16 Last Post — 08-02-2008 03:55 PM
no new posts
