Upgrade to Premium
Polaris: GEN 1 and older 1998 and older, all models in the Gen 1 Indy chassis and older chassis models
Reply
  #1
Old 01-06-2017, 04:20 PM
Mark1368 Mark1368 is offline
Currently: Not set.
Basic Member
Mark1368 is an unknown quantity at this point
Default Coolant leak around spark plug (polaris 95)
I have a Coolant leak around the spark plug hole on two of the three spark plugs. Where do I start?
Rate this post: Yes | No
  #2
Old 01-06-2017, 05:12 PM
1madbird's Avatar
1madbird 1madbird is offline
Currently: Pro engine build starting soon
1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute1madbird has a reputation beyond repute
Default
I assume this is an XLT. The purple head cover is only a cover the actual head is under the purple cover. There is an outer o-ring and then 3 small o-rings that seal where the spark plug hole comes up out of the head cover. Just need to remove the cover and go to the dealer and get all new o-rings to reseal it. See the attached picture showing the bolt torque and the o-ring with a shim and some sealant
Click image for larger version
Name:	XLT head cover.jpg
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Spark Plug - dual spark vs single spark Thread Starter — SledsWest Forum — Fouled Plug Replies — 2 Last Post — 08-19-2012 12:36 AM
Thread — Coolant Leak From Around Spark Plug? Thread Starter — csh48N116W Forum — Ski-Doo: XP Sleds Replies — 4 Last Post — 12-24-2009 12:06 PM
Thread — 2002 Polaris Pro-X Coolant leak Thread Starter — Ride 13 Forum — Polaris: EDGE Replies — 4 Last Post — 11-16-2009 02:17 AM
Thread — Can't find coolant leak on M7- would it be OK to use radiator stop leak? Thread Starter — WYrider Forum — Arctic Cat Replies — 14 Last Post — 09-06-2008 08:20 AM
Thread — polaris turbo spark plug help Thread Starter — 1madbird Forum — Performance/Modified Replies — 9 Last Post — 02-08-2008 05:04 PM
no new posts
