Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 01-03-2017, 03:25 PM
tomfg tomfg is offline
Currently: Not set.
Basic Member
tomfg is an unknown quantity at this point
Default Universal Voltage Regulator installation
Regarding 1987 Ski-doo Safari 377,
non electric start.
I purchased a voltage regulator listed to
fit the above sled. It only has one wire (yellow)
to hook up. The wiring diagram shows the
voltage regulator having a two wire hook-up,
one black wire hooking up to a "yellow / black"
wire in the harness, and the other, Yellow,
hooking up to yellow.
Assuming the "regulator black" to "harness yellow/black"
was a ground circuit, I hooked up the new
regulator yellow wire to the yellow in the harness,
hooked nothing up to the harness yellow/black,
but ran a ground wire to the new regulator
mounting pad, then to the engine.
Long story short, I fired it up, lights very bright,
revved it up, and burnt out the high beam.
It does not appear the new voltage regulator is
working.
Will the new universal "one wire" voltage
regulator work, and if so, how do I wire it up?
Thanks, Tom
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Voltage regulator Thread Starter — boondocker155 Forum — Polaris: Pro-Ride Replies — 9 Last Post — 04-01-2014 08:42 AM
Thread — Voltage Regulator went out...which one? Thread Starter — Rmk_RDR Forum — Polaris: Pro-Ride Replies — 11 Last Post — 01-11-2014 05:35 PM
Thread — voltage regulator? Thread Starter — shawn420 Forum — Polaris: GEN 2 Replies — 16 Last Post — 02-25-2013 12:40 PM
Thread — Voltage Regulator Thread Starter — KDD Forum — Polaris: IQR Replies — 3 Last Post — 01-16-2010 05:22 PM
Thread — Do I need a voltage regulator? Thread Starter — akmc800 Forum — Arctic Cat: M Series Replies — 2 Last Post — 11-18-2009 09:47 PM
