Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 01-03-2017, 12:50 PM
christopher's Avatar
christopher christopher is online now
Currently: Husky Powered, Woof Woof
christopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond reputechristopher has a reputation beyond repute
Garage
Default WANTED: What is the Best Skid Plate for the 850????
So.
After MUCH CARNAGE and BREAKAGE of multiple Chaincases I need to buy three Skid Plates!
Very Specifically need GREAT PROTECTION of the bottom of the chaincase where it is exposed beneath the boards.
Who makes the HOT TICKET in the Ski-Doo field???
__________________
Rate this post: Yes | No
  #2
Old 01-03-2017, 01:58 PM
Andystoy Andystoy is offline
Currently: Not set.
Andystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond reputeAndystoy has a reputation beyond repute
Smile What is the Best Skid Plate for the 850????
Hi Chris: Same answer as previous thread: rpmcomposites.com.
Talk to Raffi, should be a two piece that covers the whole underside, used by the guys that won the Alaska Ironman last year?
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to Andystoy For This Useful Post:
christopher (01-03-2017), sledhead_24_7 (01-03-2017)
  #3
Old 01-03-2017, 02:18 PM
Motodrew's Avatar
Motodrew Motodrew is offline
Currently: IG @Motodrew
Motodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond reputeMotodrew has a reputation beyond repute
Garage
Default
I don't know if RPM Composites has anything for the 850 available yet. That would be one pricey option to outfit 3 sleds. Skinz is supposed to be offering a skidplate, but I haven't seen it yet other than the digital renderings in their catalog. Skidoo's skidplate covers the area in which you took the hit, however I'm not sure if it's hard plastic would have prevented your damage. I do think it is the best option/value however.
The Following User Says Thank You to Motodrew For This Useful Post:
  #4
Old 01-03-2017, 02:28 PM
Wapow Wapow is online now
Currently: Not set.
Wapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond reputeWapow has a reputation beyond repute
Default
I suspect the Doo skid plate works pretty well to protect the bottom of the chaincase (currently waiting for Grip and Rip to release it's bracing solution before I install mine), because this issue does not seem to be reported much, and the bottom of the case has been sticking down in a vulnerable spot since the T3s were first released. The chaincase is magnesium, so it's pretty soft/fragile. I'm guessing the plastic of the skid plate provides cushioning and a slicker running surface to bounce off of, which helps prevent against the type of damage you suffered. That said, if you hit rocks with these sleds, you're going to wind up with damage.
The Following User Says Thank You to Wapow For This Useful Post:
  #5
Old 01-03-2017, 02:33 PM
sledhead_24_7's Avatar
sledhead_24_7 sledhead_24_7 is online now
Currently: pow hunting on the 850
sledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond reputesledhead_24_7 has a reputation beyond repute
Default
The skidoo plate DOES NOT cover the chain case area nor the brake area. Stops just before those areas.
__________________
2019 Summit X 850 175X3"
The Following 2 Users Say Thank You to sledhead_24_7 For This Useful Post:
christopher (01-03-2017), TURBOXP09 (01-04-2017)
  #6
Old 01-03-2017, 02:34 PM
Default
Last I talked with Raffi at RPM composites he had the back half of the plate done and was almost done with the front half. Sounded like a person could bolt on the back half now then front half later.
__________________
The Following User Says Thank You to sledhead_24_7 For This Useful Post:
  #7
Old 01-03-2017, 02:43 PM
Motodrew's Avatar
Garage
Default
Quote:
Dang! You're right! I would have double checked it myself if my E-Module wasn't currently being replaced at the shop!
  #8
Old 01-03-2017, 03:28 PM
Garage
Default
I need some ARMOR PLATING to protect that chaincase from any further abuse!
__________________
  #9
Old 01-03-2017, 03:49 PM
Default
Quote:
Have checked out RPM Composites yet?
I've had excellent results with their products over the years.
I've smoke some big rocks and stumps over the past few years. Thankfully barely even a scratch on my previous skid plates from them.
Last year in particular I hit a boulder the size of a VW Bug ( at least) in a white out. Had me some superman skills for a few seconds. I went 30 ft one way and sled landed 40 ft away they other. Barely a scratch, nothing bent, broke etc.
__________________
  #10
Old 01-03-2017, 04:06 PM
Motorbreath_ Motorbreath_ is online now
Currently: Loving my Summit 850!!
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
Default
Yes, but there weren't any 850's around last year.
From the slight impacts I've read about, there has been some major carnage in these past few months.
I had a RPM Composites skid plate on my old Freeride. I remember it being very heavy! but great coverage. I'm not sure a skidplate is going to prevent the bulk head from cracking like that though.
  #11
Old 01-03-2017, 05:58 PM
Click Here to Register
christopher (01-04-2017)
  #12
Old 01-04-2017, 10:56 AM
Currently: Not set.
christopher (01-04-2017), sledhead_24_7 (01-04-2017)
  #13
Old 01-04-2017, 11:18 AM
mountainhorse's Avatar
mountainhorse mountainhorse is online now
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
The Following 2 Users Say Thank You to mountainhorse For This Useful Post:
  #14
Old 01-04-2017, 01:06 PM
Garage
  #15
Old 01-05-2017, 12:45 PM
HeavyBrewster HeavyBrewster is offline
Currently: basic
Basic Member
HeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond reputeHeavyBrewster has a reputation beyond repute
  #16
Old 01-05-2017, 05:08 PM
live to ride live to ride is offline
Currently: Not set.
Basic Member
live to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond reputelive to ride has a reputation beyond repute
  #17
Old 01-05-2017, 06:09 PM
Garage
  #18
Old 01-05-2017, 06:57 PM
Currently: basic
Basic Member
  #19
Old 08-01-2018, 09:42 AM
Blk88GT's Avatar
Blk88GT Blk88GT is online now
Currently: THE CHASE IS ON!!
Blk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond reputeBlk88GT has a reputation beyond repute
  #20
Old 08-01-2018, 11:14 AM
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Wanted: M Series Skid Plate - Black or White Thread Starter — Brett Slagle Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 0 Last Post — 05-20-2012 07:43 PM
Thread — Skid plate/float plate IQR/IQRR? Thread Starter — iq6rr Forum — Polaris: IQR Replies — 2 Last Post — 06-23-2010 06:21 PM
Thread — WANTED, '08 Polaris D7 skid plate or float plate Thread Starter — fightstrap50 Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 1 Last Post — 09-20-2009 08:33 PM
Thread — Apex skid Plate Wanted Thread Starter — Tige Forum — Yamaha Replies — 9 Last Post — 11-04-2008 10:16 PM
no new posts
