Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 12-31-2016, 01:21 PM
madsledder madsledder is offline
Currently: Not set.
Basic Member
madsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond repute
Default viper eabc boost backwards
Bought sled new last year at the end of the season. 2015 viper mtx 190 Yamaha acc turbo kit installed by dealer. Not a lot of snow to play with last year so now that I'm riding this is what ive noticed. Boost seems to be high at 2000' 7psi was more I dropped it.**And lowers as I go up in altitude 5psi at 6000'.* Also it seems to run crappy after it is warmed up and sits for a bit. After I run it for a bit it clears up maybe 1/2 km down the raod. Temps outside were cold probably -10. I have looked and all plumbing seems to be ok.
0 out of 1 members found this post helpful. Rate this post: Yes | No
  #2
Old 01-01-2017, 01:54 PM
Currently: Not set.
Basic Member
Default
I have removed the eabc and solenoid and will go out maybe tomorrow. Could a faulty map senser cause this? Solenoid seems fine. So question is eabc or map senser?
  #3
Old 01-01-2017, 02:21 PM
stingray719 stingray719 is offline
Currently: 2014 Viper MTX conversion
stingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond reputestingray719 has a reputation beyond repute
Default
Quote:
Not trying to be a smart azz but call MPI would be my suggestion -*http://mountainperformance.com/support.htm
  #4
Old 01-01-2017, 02:38 PM
Currently: Not set.
Basic Member
Default
I have emailed them but I have had no reply . I assume it was because of the holidays. I will try calling them this week just trying to figure out the problem.
  #5
Old 01-02-2017, 02:02 PM
Currently: Not set.
Basic Member
Default
Talked to mpi today. Sending all the electronics and eabc valve in to be checked.
The Following User Says Thank You to madsledder For This Useful Post:
stingray719 (01-04-2017)
  #6
Old 01-12-2017, 03:55 AM
Currently: Not set.
Basic Member
Default
All my stuff is on its way back to me. But every thing tested good. Hopefully it was just a poor conection. He did mention that some have a flash in the ecu that keeps the #1 injector on. Any body know about this? Going to find out if they flashed the sled before I picked it up.
  #7
Old 01-21-2017, 06:51 PM
Currently: Not set.
Basic Member
Default
Well had it out again today. And still as I go up boost drops. I unplugged the eabc and it will not build over 5 psi. Gonna have to call mpi again. Gotta be something in turbo recirculation valve maybe or turbine it self. It just will not compress air at higher altitude. It starts to drop off about 4500'.
  #8
Old 01-22-2017, 08:57 PM
sidehil's Avatar
sidehil sidehil is offline
Currently: Husky 501 is in the house:))))
sidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond reputesidehil has a reputation beyond repute
Default
Call MPI, my kit has been flawless but I installed at home, they are a good outfit period!
__________________
2015 Blue Viper-T, 06 Apex, 08 1300 FJR, 11 Wr-250R Husky FE 501
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #9
Old 01-25-2017, 09:22 AM
Currently: Not set.
Basic Member
Default
I have contacted a few times not the problem. They have been good. Might have found the problem now. Air box has a popped weld on one of the throttle body spouts. Going to have it welded up today and try again hopefully tomorrow.
  #10
Old 01-26-2017, 05:57 PM
Currently: Not set.
Basic Member
  #11
Old 02-20-2017, 10:52 AM
Currently: Not set.
Basic Member
Click Here to Register
yamahajohnson220 (02-21-2017)
  #12
Old 03-16-2017, 11:41 AM
Currently: Not set.
Basic Member
  #13
Old 03-27-2017, 06:04 PM
Currently: Not set.
Basic Member
  #14
Old 04-09-2017, 10:28 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2015 boost it viper mtx Thread Starter — noob Forum — Yamaha (Swapmeet) Replies — 0 Last Post — 03-31-2015 01:39 PM
Thread — boost it viper finally home Thread Starter — noob Forum — Vipers! Replies — 15 Last Post — 11-08-2014 09:34 PM
Thread — boost it viper freaking rocks!! Thread Starter — noob Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 20 Last Post — 04-25-2014 04:42 PM
Thread — Boost-It Viper vids Thread Starter — NM Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 19 Last Post — 03-27-2014 09:28 PM
Thread — Viper getting some real boost from supreme of the extreme Thread Starter — Tarzannr1 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 2 Last Post — 04-05-2013 12:15 PM
no new posts
