Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 12-31-2016, 04:49 AM
Swdqo Swdqo is offline
Currently: Not set.
Basic Member
Swdqo is an unknown quantity at this point
Default 99 488 Using Too Much Oil
My dads old 99 Indy Touring 488 is using at least twice the oil it should be. This determined by tracking milage vs oil used. Is there an adjustment or does the oil pump need to be changed?
Rate this post: Yes | No
  #2
Old 12-31-2016, 01:42 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
There is a scribed line on the oil pump lever that should be lined up with another line on the housing with the throttle in idle position. It is adjusted by loosening the jamb nut on the oil pump cable at the pump end and turn other nut to line up marks. Snug up jam nut and your done. Did it suddenly start using too much oil or has it always been like that? If it has changed it could be a faulty pump or a leak in one of the lines.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #3
Old 01-06-2017, 09:53 AM
sled_guy's Avatar
sled_guy sled_guy is online now
Currently: In limbo
sled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond reputesled_guy has a reputation beyond repute
Default
Make sure you are tracking fuel used vs oil used, not mileage. The oil needs to mix at a ratio with the fuel, which can be very different when compared to miles.
sled_guy
__________________
"Sorry, I thought you could ride"
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Help with 97 488, Fuel pump? Thread Starter — sledheader Forum — Polaris: GEN 1 and older Replies — 2 Last Post — 01-25-2014 07:45 AM
Thread — Is the 488 called the 500? Thread Starter — SpencerA Forum — Polaris: GEN 1 and older Replies — 11 Last Post — 09-22-2013 10:11 PM
Thread — 488 vs 440 Thread Starter — bowtieboy Forum — Polaris: GEN 1 and older Replies — 6 Last Post — 01-17-2011 02:46 AM
Thread — 488 clutching please help Thread Starter — revelized Forum — Performance/Modified Replies — 3 Last Post — 11-24-2008 09:29 PM
Thread — jetting a 488 with pods Thread Starter — revelized Forum — Performance/Modified Replies — 9 Last Post — 12-16-2007 07:05 PM
no new posts
