Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 12-28-2016, 11:23 PM
itsgunnaBaClinic10 itsgunnaBaClinic10 is offline
Currently: Not set.
Basic Member
itsgunnaBaClinic10 is an unknown quantity at this point
Default 04 polaris
Hey everyone, im working on a 04 Polaris verticle ecscape 700 with 151" 1 3/4" trck for a friend I need a little help! He wants it geared down so the top speed is only 80mph I can't find what stock gearing is nor can I find the average top speed at stock. hope you guys and girls can help!
Rate this post: Yes | No
  #2
Old 01-09-2017, 08:35 AM
Cerialsledder's Avatar
Cerialsledder Cerialsledder is offline
Currently: Flatlanderextraordinaire
SnoWest Badge Maker
Cerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond reputeCerialsledder has a reputation beyond repute
Garage
Default
Moved this thread to the appropriate section so that it would get more attention.
__________________
  #3
Old 01-09-2017, 09:53 AM
BILTIT's Avatar
BILTIT BILTIT is online now
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
Check how many teeth are on each sprocket in the chain case. A few different options available from factory so best to just check yourself.
Use this calculator to check Theoretical MPH.
http://www.turboaddictionparts.com/c...alculator.html
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
  #4
Old 01-16-2017, 12:55 AM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
The more teeth you add to the bottom sprocket, the greater the likelihood that you will need a longer chain. Just adding one tooth to the bottom sprocket, significantly improves climbing performance. But if the goal is to improve performance, you might want to go with a camoplast challenger 2" high lug with 3 lugs across.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Kurts Polaris gear down kit for polaris pro 2013 to 2015. Thread Starter — WFOWA Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 4 Last Post — 01-05-2016 09:34 PM
Thread — New Pair of Polaris RMK Pro Hyfax Polaris Part #5521633-309 Thread Starter — Twitma93 Forum — Misc. Sled Parts Replies — 0 Last Post — 04-03-2015 12:34 PM
Thread — Attention Polaris: In-House Polaris Tech in Training PIC HEAVY Thread Starter — diamonddave Forum — Polaris: Pro-Ride Replies — 10 Last Post — 10-22-2014 06:42 PM
Thread — Polaris Edge Lightweight hood w/ Tri City Polaris Vent kit FS Thread Starter — ProRide800155 Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 4 Last Post — 01-08-2013 02:16 PM
Thread — 1999 polaris 700 RMK and 1996 polaris indy 500 Thread Starter — snow addict Forum — Polaris (Swapmeet) Replies — 0 Last Post — 05-12-2009 09:04 PM
