Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 12-27-2016, 06:42 PM
2ahoser 2ahoser is offline
Currently: Not set.
Basic Member
2ahoser is an unknown quantity at this point
Default Oil lines after disassembly?
Howdy,
Putting together my 2000 800RMK engine, and mostly got it back together, and got the oil pump attached to the housing. I bleed the oil pump by removing the top bleed screw and let oil come out. I have the plugs removed and the fuel line turned off, and with the throttle locked open, so that the oil pump is open fully, I see no oil coming out of the lines when I pull about 20 times on the recoil rope.
I removed on oil line right at the pump and I don't see any oil coming out that one line?
I have a new belt on the water/ oil pump drive, so is it possible I don't have engaged correctly? It seems like I turned it to key it in the drive?
Was planning on doing mix in the gas for the first couple of tanks, but wanted to get oil to the bearings too....
What am I missing? is it going to spin faster once it's started and fill the lines? Or do I need to fill the lines to get the air out?
Any advice or links would be appreciated
Thanks
Bob
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Where do the oil lines go? Thread Starter — jskattum606 Forum — Polaris: IQ Replies — 2 Last Post — 09-15-2012 09:50 AM
Thread — Oil tank & Oil lines Thread Starter — 907assault Forum — Polaris: Pro-Ride Replies — 3 Last Post — 12-04-2011 12:24 AM
Thread — Crank injector oil lines.... not seeing oil ( pic) Thread Starter — cruiser76 Forum — Ski-Doo: ZX Sleds Replies — 5 Last Post — 02-22-2011 09:28 PM
Thread — Oil Lines Thread Starter — rocks rev Forum — Ski-Doo: REV Sleds Replies — 0 Last Post — 12-26-2010 07:25 PM
no new posts
