Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 12-19-2016, 12:06 PM
Agrilife Agrilife is offline
Currently: Not set.
Basic Member
Agrilife is an unknown quantity at this point
Default 2005 M7 Question about belly pans
I have a 2005 M7 141, the secondary clutch wore threw the belly pan. Didnt know if that was a known issue or not? I see on the 2006 m7 141 there a metal plate in the belly pan and different part number for the belly pan itself. i wanted to know if the 2006 belly pan parts would fit my 05 m7.
Rate this post: Yes | No
  #2
Old 12-19-2016, 06:29 PM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
I'm 99% sure that '06 panels will fit your '05. Nearly as sure that any year side panel will fit, up to 2011. I'm assuming you wore through the side, not the bottom. Although I'm pretty sure the bottoms are all the same also.
You'll get more sure answers in the M-series sub-forum though, if you need. This is technically the forum for the older 1M chassis, like the King Cat.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
  #3
Old 12-19-2016, 07:33 PM
boondocker97 boondocker97 is offline
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
I wore through my stock 2005 M7 belly pan too. When cat went to the 10.4 secondary as stock, they deepened the belly pan with an insert. Not sure when that started. I upgraded my whole belly pan on that side to the new style. Mine was from a 2009 m-series. Not sure if you can just get the newer insert plates and cut out your belly pan you already have, but I would try that first. If that doesn't look like it would work for some reason then you could get the entire belly pan like I did.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M Belly Pans Thread Starter — Phizzer Forum — Arctic Cat: M Series Replies — 3 Last Post — 01-05-2014 09:19 PM
Thread — m series belly pans Thread Starter — PeakPerformance04 Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 7 Last Post — 04-07-2013 01:59 PM
Thread — 2005 to 2011 M series Belly pans-Orange Thread Starter — RACINSTATION Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 0 Last Post — 03-10-2012 09:27 PM
Thread — Belly Pans??? Interchange Thread Starter — 01ZRTCAT Forum — Arctic Cat: 1M Replies — 2 Last Post — 10-03-2011 12:24 PM
Thread — 04 kk orange belly pans Thread Starter — grayghost Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 1 Last Post — 01-21-2009 10:14 PM
