Upgrade to Premium
Ski-Doo: S-2000 and older 1998 and older, all models in the S-2000 chassis and older chassis models
Reply
  #1
Old 12-14-2016, 10:04 AM
MSP381 MSP381 is offline
Currently: Not set.
Basic Member
MSP381 is an unknown quantity at this point
Default Changing pto side crank seal
Anybody know if I have to split the case to change the crank seal on a 99 summit x 670?
Thansk
Rate this post: Yes | No
  #2
Old 12-14-2016, 11:40 AM
nuttyn01 nuttyn01 is offline
Currently: Not set.
nuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond repute
Default
Imo yes. I've seen guys do it without splitting the case and thats not my style. I would also highly recommend changing the outer pto crank bearing and checking the crank end run out.
When you run the engine and the pto seal goes out it typically burns down that cylinder due to the increase in air being brought in through the seal. This ingestion of air also sweeps oil off the outer pto bearings and they run dry and cause damage. I've seen guys just replace the seal only to turn right around and do bearings and crank. These motors were absolute powerhouses in the day. Still one of my favorites.
  #3
Old 12-14-2016, 03:53 PM
eddy's Avatar
eddy eddy is online now
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Thumbs up PTO Seals
There are two and one in inboard of the bearings. If the inboard seal fails, the outer will fail shortly after. So best practice is to split the cases and replace all seals and inspect bearings. In most cases if you catch the issue right after the PTO seal shows symptoms - the bearings are still good and do not need to be replaced. This holds true for the iosflex lubed bearings as well.
New seals (and Iso if applicable) and you are good to go.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — PTO crank seal Thread Starter — jd440 Forum — Ski-Doo: REV Sleds Replies — 0 Last Post — 02-17-2014 08:59 AM
Thread — changing PTO side crank seal Thread Starter — fullboredragon Forum — Polaris: Pro-Ride Replies — 4 Last Post — 02-08-2013 04:24 PM
Thread — PTO Crank Seal? Thread Starter — PusherMan99 Forum — Polaris: IQ Replies — 1 Last Post — 04-01-2011 06:26 AM
Thread — New Polaris PTO Crank Seal For Sale Thread Starter — Poleman Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 03-08-2011 08:59 PM
Thread — Crank PTO seal help Thread Starter — keefer Forum — Ski-Doo Replies — 1 Last Post — 03-01-2010 11:10 AM
no new posts
