Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 12-12-2016, 11:01 AM
Wrenchmaster's Avatar
Wrenchmaster Wrenchmaster is offline
Currently: working when I should be riding
Wrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond reputeWrenchmaster has a reputation beyond repute
Default 2009 M8 CPC stage II boost & fuel
I know it's likely been posted in the past, but must have been archived, so I'm starting a new thread.
Anyone know what boost PSI the Stage II CPC wastegate actuator is set at? I'm running the PG one now, and want to run higher boost this year with race gas.
Also, should I run straight C12, or mix with premium or 100LL AV gas?
We ride 2500 - 9500 feet. Usually 6500 up is where we're doing most of the big pulls, running high boost. Anyone have some fuel box settings to start with at these elevations?
TIA
Rate this post: Yes | No
  #2
Old 12-13-2016, 01:35 AM
HCR10 HCR10 is offline
Currently: 2016 cat turbo and 2013cat turbo for her
HCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond reputeHCR10 has a reputation beyond repute
Default
Call and talk to Dale at cutlers he is always really good at pointing you in the right direction and he will give you everything you need.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 12-13-2016, 11:14 AM
Default
I've talked to him. He makes 3 different actuators, didn't know which one I have and didn't know what fuel I should run either since he couldn't tell me how much boost this actuator will make. I'm pretty sure I've got the 8PSI one. Guy I got it from said it's for race gas, and since it's a stage 2 kit, I'm thinking it's the medium boost one.
Guess I'll run race gas, or 50/50 C12/AV and just tune it with my AFR/EGT
Would still like to know what's working for others with this kit so I have a starting point
  #4
Old 12-14-2016, 12:39 PM
M-Head M-Head is offline
Currently: Needing a sponsor for my sled addiction.
M-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond reputeM-Head has a reputation beyond repute
Default
The race gas actuator is 9-14 lbs, but I don't know the part #.
  #5
Old 01-08-2017, 06:19 PM
BENDER 151 BENDER 151 is offline
Currently: waitin to go rippin
Basic Member
BENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond reputeBENDER 151 has a reputation beyond repute
Default
I'm running dales stage 2 kit on my 2011 m8.I run 80%av gas 20% 91 at 8 lbs boost still runmindful a bit richigher on Avr
gauge but I'm good with it
The Following User Says Thank You to BENDER 151 For This Useful Post:
Wrenchmaster (02-03-2017)
  #6
Old 01-11-2017, 02:04 PM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
On there site Stage 2 is 6/10 psi
__________________
M 1000 modded but no turbo no way Uh well maybe
The Following User Says Thank You to Hardass For This Useful Post:
  #7
Old 02-03-2017, 05:27 PM
Default
bender 151 What elevations are you running?
Talked to a shop in my area, they say I need an intercooler and C12 for 12 psi, I'll stay with AV I think, can't afford C12 at $150 for 20L!!!
That'd be $300 per tank, who can afford that? bloody crazy!
I'm thinking 100% AV and 10PSI at 5K feet and up
That sound safe?
  #8
Old 02-05-2017, 08:51 PM
Default
Do you know what your fuel box settings are? I've been adjusting mine, still sputtering on the top end though, seems rich, but AFR numbers are pretty close
  #9
Old 02-08-2017, 01:46 PM
Hardass's Avatar
Currently: Not set.
Default
I run a mix of 98 octane in my set up between 4500/6500 @10 psi but my set up is different there are so many variables
__________________
  #10
Old 03-03-2017, 06:03 PM
gongshowm1000 gongshowm1000 is offline
Currently: Wrenching to ride
gongshowm1000 is an unknown quantity at this point
  #11
Old 03-04-2017, 09:11 AM
Hardass's Avatar
Currently: Not set.
Click Here to Register
Wrenchmaster (03-19-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2009 M8 CPC Stage Three Turbo Thread Starter — smitwad Forum — Arctic Cat (Swapmeet) Replies — 18 Last Post — 03-18-2013 10:14 AM
Thread — cpc stage 1 lost fuel pressure Thread Starter — mocflats Forum — Arctic Cat: TURBO Replies — 2 Last Post — 12-29-2012 09:09 PM
Thread — 2009 HCR 800 CPC Stage 3 Thread Starter — smitwad Forum — Arctic Cat (Swapmeet) Replies — 3 Last Post — 05-03-2012 02:42 PM
Thread — 2009 HCR CPC Stage 3 Turbo Thread Starter — smitwad Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 11-25-2011 02:54 PM
Thread — 2009 CPC Stage 2 TM800 Thread Starter — mynewuseddoo Forum — Arctic Cat (Swapmeet) Replies — 3 Last Post — 04-08-2011 08:23 PM
no new posts
