Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 12-10-2016, 09:48 PM
ponchonutty ponchonutty is offline
Currently: Not set.
Basic Member
ponchonutty is an unknown quantity at this point
Default 93 Arctic Cat Jag FC440 no spark
I bought this sled that had caught on fire. It melted the harness so I decided to buy a used harness. I am 99% sure I bought the right harness but now I have no spark. What do I need to look for? The odd thing I did notice is that the old harness had a 2 pin harness from the safety switch. The new harness has 3 pin harness but so does the replacement handlebar. I can only think the replacement harness is no good, I have one that won't work, or I have something not hooked up correctly. This new harness does have a 6 pin plug that I can't figure out what it's for. The old harness was burnt so bad that I can't compare. Any held would be great!
Rate this post: Yes | No
  #2
Old 12-11-2016, 09:11 AM
6000rr 6000rr is offline
Currently: Not set.
Basic Member
6000rr is an unknown quantity at this point
Default
Have you tried checking for spark with the kil switch down? We had a 90 prowler 440 l/c that was backwards after replacing some electrical parts. To kill the sled, you had to lift up on the killswitch and push the throttle and it would shut down
  #3
Old 01-22-2017, 11:49 PM
Currently: Not set.
Basic Member
Default
Yes. I found that out too so now I have spark. Found out the cranks seals were crap so I had them replaced but now still have same issue I had after I got the wiring straightened out. It acts like it's not getting fuel at times. I've replaced EVERYTHING fuel related. New pump, new lines, new filter, new pickup, and even a new NOS carb. It will start for a few when I dump fuel in the cylinder but once that burns off it stalls. It did run longer a few times but not long enough to get carb adjusted. What gives
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — parts for arctic cat jag 440 Thread Starter — powderrushsh Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 0 Last Post — 10-18-2011 09:00 AM
Thread — 1980 Arctic Cat Jag 3000 f/c Thread Starter — chibravo Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 04-03-2011 12:49 PM
Thread — Arctic Cat Jag Help Thread Starter — ArcticCat99 Forum — Arctic Cat Replies — 1 Last Post — 09-16-2009 10:30 AM
Thread — 1992 Arctic Cat Jag 440 Thread Starter — snow225 Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 04-09-2008 01:08 PM
no new posts
