Upgrade to Premium
Reply
  #1
Old 12-05-2016, 06:02 PM
RotaxKongen RotaxKongen is offline
Currently: Not set.
Basic Member
RotaxKongen is an unknown quantity at this point
Default IQ600RR - 800 mod?
Hello! Is it possible to put 800 VES or 800 CFI cylinder on it?
Rate this post: Yes | No
  #2
Old 12-07-2016, 05:56 AM
Goinbyyabig Goinbyyabig is offline
Currently: In the shop
Basic Member
Goinbyyabig is an unknown quantity at this point
Default
If the sled is a 2008 600rr, with the original engine, a 600HO, then no. If it's a race sled, 2008 and up, with the 600 long stroke engine, you can use the 800 cylinders, after machining the crank case to accept the bigger cylinder skirts.
Guys used to install an 800 VES "big block" engine in mod sleds, but it requires a bunch of cutting on the bulkhead to clear the water pump, and an engine plate made specifically for this combo. Also, the steering support and column/shaft needs to be cut and bent around the cylinders, as the stock factory straight pieces won't accept the motor. This engine also requires a different primary clutch, and the factory airbox won't work.
Much better option is to get the 800 CFI engine and bolt it in without hacking the sled to pieces.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — iq600rr stock pipe and can Thread Starter — wingedwheel90 Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 02-22-2014 03:47 PM
Thread — 2008 Iq600rr Skinz silencer Thread Starter — redred55 Forum — IQR Parts Replies — 1 Last Post — 02-04-2014 09:16 PM
Thread — 2008 ski-doo rs 600 mod & 800 mod for sale Thread Starter — newgard Forum — Ski-Doo (Swapmeet) Replies — 6 Last Post — 05-16-2010 06:20 PM
Thread — WTB IQ600rr or IQR Thread Starter — Bodey Forum — Polaris (Swapmeet) Replies — 2 Last Post — 09-29-2009 09:00 PM
no new posts
