Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 12-05-2016, 05:50 AM
ACTM7 ACTM7 is online now
Currently: Not set.
ACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond reputeACTM7 has a reputation beyond repute
Default Evo update for mpi vipers who's ran it
Has anybody body ran the evo upgrade on the mpi vipers ?
Rate this post: Yes | No
  #2
Old 12-05-2016, 02:13 PM
catdieselpwr catdieselpwr is offline
Currently: Not set.
Basic Member
catdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond reputecatdieselpwr has a reputation beyond repute
Default Evo mpi upgrade
I have one ride on mine, its the 15 mtx viper, I did the reflash, injectors, and studs. I like it so far.
  #3
Old 12-05-2016, 09:14 PM
RMKing1 RMKing1 is offline
Currently: Not set.
Basic Member
RMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant futureRMKing1 has a brilliant future
Default
How is the response catdieselpwr and overall feel of increase over the base 190 kit also did you remove the engine to do the stud's and have you had to mess with your GEMS box much above and beyond the new EVO setting's for it?
  #4
Old 12-20-2016, 09:58 PM
madsledder madsledder is online now
Currently: Not set.
Basic Member
madsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond repute
Default
Any more on this. I'm considering the upgrade too. Is it a noticeable difference? Would you do it again?
  #5
Old 12-31-2016, 10:00 PM
Currently: Not set.
Basic Member
Default evo update
Hey guys, I've rode this update 5 trips now and heres what i have to say, First off, its a freight train @ 10 psi with pump gas@ 5k plus elevation. It feels like my old 240 mcx nytro. Second you have to control your own boost or have the mpi boost controller reflashed for your desired boost #, i put a turbo smart in place and manage my throttle when coming down the mountain. Third the rev limiter being raise to 9750 rpm is bada$$ especially for the clutching, as im sure you've all heard yours bouncing off the rev limiter, i have it tuned for 9350 and it flat out goes. Now for the cons, and theirs only one that i have for this entire reflash is the off idle to mid range bull#$@! blubber that it does. I've talked with Kyle at evo and he says that its from not having dielectric grease on all connections which i did and do on all electrical connections, he responded that he has never heard of such a blubber or complaint but Dustin @ outlaw says hes had multiple evo flashes that do. Dustin also says they had the blubber tuned out on the early test sled reflashs, but for some reason they are sending out blubbering reflashed ECU. Its still ride-able but very annoying when @ cruising speeds or descending from a climb. Sorry for or if I bashed anything or anyone but theirs not many Vipers that are out there and maybe this will help.
  #6
Old 01-01-2017, 01:01 AM
Currently: Not set.
Basic Member
Default Evo reflash II
As far as the studs go, I did not have to pull the engine. I removed all the motor mount bolts and rocked the engine forward enough the get the tensioner loose and out. It was not bad to do, probably took me start to finish approximately 4.5 hrs. Evo instructions were very thorough. . The gems box was adjusted very little, I put a innovate afr to see what things were doing. The injectors were an easy 15 min install as well.
  #7
Old 01-02-2017, 05:50 PM
snowy1 snowy1 is offline
Currently: Not set.
Basic Member
snowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enoughsnowy1 will become famous soon enough
Default
Quote:
I am having the same issues bottom and mid range, I talked to Dustin as well hopefully they come up with a fix soon.
  #8
Old 01-11-2017, 01:50 PM
05M7 05M7 is offline
Currently: Not set.
05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute05M7 has a reputation beyond repute
Garage
Default
I just talked with evo and they said they have the midrange issue solved they are having me send my ecu in. ive got probably 150 miles on mine and it pulls hard!
  #9
Old 01-27-2017, 10:02 PM
Currently: Not set.
Basic Member
Default
Got the reflash from evo and no more issues runs good from bottom to top now
  #10
Old 09-11-2017, 09:18 PM
Currently: Not set.
Basic Member
  #11
Old 09-17-2017, 10:47 PM
motojunkie101's Avatar
motojunkie101 motojunkie101 is offline
Currently: Yamaha 4 stroke moderator
MODERATOR: Premium Member
motojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond reputemotojunkie101 has a reputation beyond repute
Garage
Click Here to Register
The Following User Says Thank You to motojunkie101 For This Useful Post:
RMKing1 (10-11-2017)
  #12
Old 10-11-2017, 01:16 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — EVO Upgrade Kit for Factory MPI Vipers are coming soon Thread Starter — Evolution Powersports Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 28 Last Post — 09-22-2016 03:39 PM
Thread — Upgrade Turbo Kit for MPI Vipers is coming soon! Thread Starter — RACINSTATION Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 16 Last Post — 01-18-2016 09:29 AM
Thread — Any Evo Vipers out there?? Thread Starter — Prairie Dog Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 122 Last Post — 01-09-2016 10:24 PM
Thread — Anybody riding mpi sr vipers? opinions? Thread Starter — APEX SUPER Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 0 Last Post — 11-30-2014 09:55 PM
Thread — anyone have any update kits for the evo brv check valve??? Thread Starter — UtahEdge Forum — Arctic Cat: 1100 ProClimb Replies — 4 Last Post — 01-08-2014 11:31 PM
no new posts
