Upgrade to Premium
Polaris: GEN 2 1999-2001, all models in the Gen 2 chassis
Reply
  #1
Old 12-03-2016, 04:34 PM
alaska_guy alaska_guy is offline
Currently: Waiting for snow
Basic Member
alaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond reputealaska_guy has a reputation beyond repute
Default Just fired my sled up and took it for a short ride after rebuild...
So I jetted per SLP's recommendations and I just had a quick question.
My EGT guage was showing 8 on the left side and 4 on the right side. Is it normal for these twins to be unbalanced on the EGT guage? Sled rips, but just want to make sure I don't mess anything up since I just rebuild it last year and this is the first time I have been able to really ride the machine since it was rebuilt. I didn't really ride it hard or WOT, just around the block for about 10 minutes or so. Seemed around 400-600 at idle.
2001 RMK, SLP twins, ported and polished.
Thanks!
It feels a little sluggish down low too... I know with twins they can do that, but just wanted to make sure I don't need to switch jets up another size since one side is showing a lower EGT which I assume means it's running lean.
My sled does have staggered main jetting per SLP's recommendation. One side is 20 higher than the other.
Rate this post: Yes | No
  #2
Old 12-03-2016, 06:07 PM
Basic Member
Default
I think I got it fellas. I was running 470 mains. Switched them to 500's and the sled is running MUCH better. No more bog down low.
http://www.startinglineproducts.com/...ets/09-726.pdf
I used that as a guide. I run around 300-500 elevation and 0-14 degrees on average for temp.
  #3
Old 12-04-2016, 04:40 PM
slash's Avatar
slash slash is offline
Currently: ahhh back to work
Parts Moderator & Chat Box Cop
slash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond reputeslash has a reputation beyond repute
Garage
Default
higher EGT number is lean, lower or cold number is rich .
keep it below 1200 and you should be ok
mid throttle cruse @ 900 to 1000 deg is good .
always DBL check your plug reading ..
__________________
09 IQ
KMOD
RAPTORS
2.5 CE
MOHAWKS
SLP PIPE
KOOLME KUSTOMS 660 KIT
TATERSPORTING PORTWORK
[IMG]//www.snowest.com//www.snowest.com/i/snowest-forum-logo.jpg[/IMG]
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris 600 CFI Short block needs rebuild Thread Starter — GNDAN Forum — Engine/Engine Parts (Swapmeet) Replies — 9 Last Post — 01-19-2015 06:34 PM
Thread — Are you as FIRED up as this guy was to ride his new M1100T? Thread Starter — Jeff C Forum — Arctic Cat: 1100 ProClimb Replies — 35 Last Post — 12-14-2011 05:04 PM
Thread — rebuild crank or BRP short block? Thread Starter — mental health Forum — Ski-Doo: REV Sleds Replies — 14 Last Post — 09-21-2011 10:40 PM
Thread — Snowies - who's still fired up to ride? Thread Starter — Coldfinger Forum — Wyoming Replies — 31 Last Post — 05-08-2010 10:54 AM
Thread — Tacoma Double Cab Short Bed: Too short for sled? Thread Starter — JJ Forum — General Snowmobiling Replies — 14 Last Post — 06-13-2008 02:40 PM
no new posts
