Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 12-02-2016, 10:43 AM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default Electronic reverse possibility
I've been working with flatspeed on programming his M7 electronic reverse module to work on a Carbed 900. Thought some of you might be interested, and saw 1Mike900 comment in there.
//www.snowest.com/forum/showthread.php?t=412274
We're very close to getting this working.
Anyone who does this will need to either modify their secondary with encapsulated rollers, slotted for reverse, or use a solution like a Team secondary with a reverse helix.
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 5 Users Say Thank You to Idcatman3 For This Useful Post:
flatspeed (12-03-2016), Marty UT (10-29-2017), MountainTrashCat (07-05-2018), Qreiff (12-02-2016), unclemark (01-03-2017)
  #2
Old 12-02-2016, 01:36 PM
89sandman's Avatar
89sandman 89sandman is online now
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
Default
Are you guys doing the 1M900? Still think there would be a big market for the 07-08 M guys.
The Following User Says Thank You to 89sandman For This Useful Post:
  #3
Old 12-02-2016, 01:54 PM
Idcatman3's Avatar
Currently: Not set.
Garage
Default
Quote:
I'm only working with him on modifying the programming to work on the 900 Carb.
He did it for the M7 EFI. I imagine it would probably work with little to no modification on the M8, possibly the M1000, depending on what the flywheel triggers look like compared to the M7.
I think it would also work just fine as is on the 8/900 EFI engines, since they use essentially the same flywheel the M7 does.
__________________
  #4
Old 01-01-2017, 05:31 PM
unclemark unclemark is offline
Currently: Not set.
Basic Member
unclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond reputeunclemark has a reputation beyond repute
Default Reverse
Any updates on this reverse?
Would it work on bigbore sleds ?
I got a 1100 hooper In a iqr and reverse would be nice.
Any idea on cost ?
The Following User Says Thank You to unclemark For This Useful Post:
  #5
Old 01-02-2017, 09:59 PM
Idcatman3's Avatar
Currently: Not set.
Garage
Default
No updates yet. Holidays got in the way of testing. Should work on big-bores, ours is a 975. I don't know if he'll charge different for the different program. He's got the M7 ones listed at $330 Canadian.
__________________
  #6
Old 01-03-2017, 02:34 AM
Currently: Not set.
Basic Member
Default Reverse
Quote:
So would this be like a piggyback on the existing CDI box ?
Or would this be a whole new ignition system?
I know a guy that was trying to make a Polaris 800 ignition system work.. but after a while he gave up....
Brad (1200 psi) used to make a Ducati system that (didn't have the TPS sensor and you could adjust the timing on the flyer wheel ) was based off the 700 Polaris for a lot of the 1150's ..
In any case I would be interested in one 😃
  #7
Old 01-03-2017, 05:22 PM
Idcatman3's Avatar
Currently: Not set.
Garage
Default
This is a piggyback on the stock system. It's a simply box that plugs into power, and inline with the timing sensor. You hit the included button, it shuts down, and re-starts in reverse, just like the stock ones do. It does that by putting a delay on the signal coming from the timing sensor.
I have thought repeatedly about adapting either the polaris system, or a Ski-Doo 800. Biggest issue is finding a flywheel with the right taper, then getting the timing sensor location(s) correct. Also was going to wire up a second timing sensor on a switch, in the right location to run in reverse.
This should be easier once we get the programming 100% correct.
__________________
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to Idcatman3 For This Useful Post:
Marty UT (10-29-2017), unclemark (01-04-2017)
  #8
Old 09-18-2017, 07:46 AM
sprockethead's Avatar
sprockethead sprockethead is online now
Currently: Not set.
sprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond reputesprockethead has a reputation beyond repute
Default
What's up with this?
The Following User Says Thank You to sprockethead For This Useful Post:
  #9
Old 09-18-2017, 08:44 AM
Idcatman3's Avatar
Currently: Not set.
Garage
Default
Quote:
Still in progress. Life/summer got in the way, but it will work. Wrapping up farming shortly and will be getting back to the important things in life.
__________________
The Following User Says Thank You to Idcatman3 For This Useful Post:
  #10
Old 03-03-2018, 12:09 PM
1Mike900 1Mike900 is offline
Currently: Not set.
1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute
The Following User Says Thank You to 1Mike900 For This Useful Post:
  #11
Old 03-05-2018, 04:08 PM
Idcatman3's Avatar
Currently: Not set.
Garage
Click Here to Register
  #12
Old 03-17-2018, 12:01 PM
Currently: Not set.
  #13
Old 07-30-2018, 03:39 PM
Snake61047 Snake61047 is offline
Currently: Not set.
Basic Member
Snake61047 is an unknown quantity at this point
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2008 m8 Reverse cut helix, electronic reverse mod Thread Starter — IOWACATMAN Forum — Arctic Cat: M Series Replies — 9 Last Post — 12-29-2013 05:28 PM
Thread — 06 M6 Electronic Reverse Thread Starter — prairiepowderhead Forum — Arctic Cat: M Series Replies — 4 Last Post — 10-17-2011 09:32 AM
Thread — electronic reverse Thread Starter — Ski-Laxn Forum — Arctic Cat: M Series Replies — 20 Last Post — 08-01-2010 12:06 PM
Thread — Who's reverse helix for electronic reverse on '07-'08s Thread Starter — AaronBND Forum — Arctic Cat: M Series Replies — 2 Last Post — 03-01-2010 09:54 PM
Thread — electronic reverse Thread Starter — SledHed75 Forum — Arctic Cat Replies — 2 Last Post — 01-14-2009 01:37 PM
no new posts
