Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 11-25-2016, 09:21 AM
icer2001 icer2001 is offline
Currently: Not set.
Basic Member
icer2001 is an unknown quantity at this point
Default 2000 MM700
I recently picked up a 00' MM700 it has 4600mi and is in great condition. The guy I got it from rode it at 10,000ft and it has been jetted and clutch mods for that elevation. I will be riding it at 4,000-7,000ft. The clutch has the GWG spring and I have not removed it to see what rivits it has for weight. The jets I will obviously change (would stock be about right on the mains and pilots) It also has from what I can tell a Sno-stuff rumble can. Any in put or suggestions appreciated . TIA
Rate this post: Yes | No
  #2
Old 11-27-2016, 06:26 AM
LoneViper LoneViper is offline
Currently: Not set.
LoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond reputeLoneViper has a reputation beyond repute
Default
Some place I have the information you are looking for. I'm going to have to find it so hang on.
  #3
Old 11-27-2016, 09:44 PM
Currently: Not set.
Basic Member
Default
That would be great!!!
  #4
Old 11-28-2016, 03:43 PM
Currently: Not set.
Default
My 2000 MM was set up as follows,
6,000 to 8,000 ft 100% stock no pipes.
Mains, #1 - 133.8, #2&3 132.5
Piolet jet 57.5
Fuel screw 1.5 -2
Needle 1.5
clutch- Standard
I rode this stock sled every where from 4,000 feet to 10,000 and never changed a thing and it never missed a beat.
you might look this over.
http://www.zenitram-inc.com/kgmz.htm
  #5
Old 11-29-2016, 01:10 PM
Currently: Not set.
Basic Member
Default
Thanks for the info. I talked to another guy he said to try
#1 138.8
#2-3 137.5
55 pilot
np-2.5
1 3/4 turn
I found the specs for a stock clutch and got a softer spring also now I just have too take it off and see what the weight are (hoping its still all stock and I can just change the spring)
  #6
Old 11-29-2016, 02:05 PM
Currently: Not set.
Default
Sounds to me he was a little lower elevation and colder weather. Maybe pipes.
  #7
Old 11-29-2016, 08:19 PM
Cat800 Cat800 is online now
Currently: Not set.
Basic Member
Cat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond repute
Default
Any Yamaha dealer can look up your elevation and temp and tell you the stock specs on jetting and clutching.
  #8
Old 12-04-2016, 02:54 PM
tacoman tacoman is offline
Currently: Not set.
Basic Member
tacoman is an unknown quantity at this point
Default Jetting
The jetting is kind of complicated. It is based on both temperature and altitude. It is not practical to tune to the level that the manual calls for if you live in the mountains. Yamaha calls for different jets every 20degF (from -40 to +60) and every 1500ft. Typically I ride from 2500 ft to about 6500ft from 0F to about 35F. I set mine for the lowest altitude and temperature I am likely to encounter in a season. Setting up the richest practical setting. If you want I can send you the scanned page. Its going to require a little effort on my part to get my scanner working.
  #9
Old 12-05-2016, 05:24 PM
700redsled 700redsled is offline
Currently: Not set.
Basic Member
700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute
Default
put a compensater from holztmann on it and no more jetting worked great on my 700 mm
  #10
Old 12-06-2016, 09:37 AM
Currently: Not set.
Basic Member
  #11
Old 12-06-2016, 09:48 AM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 12-06-2016, 09:33 PM
Currently: Not set.
Basic Member
  #13
Old 01-06-2017, 09:52 AM
Currently: Not set.
Basic Member
  #14
Old 01-06-2017, 02:47 PM
ultimax ultimax is offline
Currently: Not set.
ultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond reputeultimax has a reputation beyond repute
  #15
Old 01-06-2017, 09:42 PM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is offline
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 2000 MM700 $1800 Thread Starter — tcpeterson Forum — Yamaha (Swapmeet) Replies — 4 Last Post — 03-27-2014 09:11 PM
Thread — 2000 MM700 in SW Wyoming Thread Starter — uintasno Forum — Yamaha (Swapmeet) Replies — 1 Last Post — 12-08-2011 12:25 AM
Thread — Parting Out 2000 MM700 Thread Starter — MNpowderfiend Forum — Yamaha (Swapmeet) Replies — 8 Last Post — 04-05-2010 10:21 AM
Thread — 2000 Yamaha MM700 Thread Starter — Silver Streak Forum — Yamaha (Swapmeet) Replies — 2 Last Post — 01-28-2008 09:29 AM
Thread — 2000 MM700 Clutching??? Thread Starter — MNpowderfiend Forum — Yamaha Replies — 4 Last Post — 01-09-2008 08:42 PM
